		TimRVator(at)comcast.net Guest
				 Posted: Sat Aug 11, 2012 6:24 am    Post subject: Nose wheel fairing breaks |
				After returning home from OSH, I noticed a chunck missing from my RV-10
 nose wheel fairing.  When flexed, the fairing ripped as shown in this photo:
 https://dl.dropbox.com/u/93114308/fairing%201.jpg
 I was surprised at how fragile the fairing was once that rip started.
 With very little force I could have ripped the whole fairing into two
 pieces.
 I patched the missing chunk and rip, then added a few layers of
 fiberglass and epoxy resin, about 5" wide, to strengthen the entire
 circumference of the fairing forward of the bulkhead.   I also added a
 1" wide reinforcement around the opening for the wheel:
 https://dl.dropbox.com/u/93114308/fairing%202.jpg
 I recommend builders consider adding reinforcement in this area of the
 fairing during construction.
 Tim Lewis -- HEF (Manassas, VA)
 RV-6A N47TD -- 1104 hrs - sold
 RV-10 N31TD -- 300 hrs
		n223rv(at)wolflakeairport Guest
				 Posted: Sat Aug 11, 2012 6:49 am    Post subject: Nose wheel fairing breaks |
				I believe the instructions tell you to reinforce the opening with 2-3 layers of glass.  I reinforced mine with carbon fiber.
 Might want to double check and make sure you have ample clearance to the wheel.  I believe I have 3/4" all around..
 -Mine Kraus
 RV-10 Flying
 On Aug 11, 2012, at 10:23 AM, Tim Lewis <TimRVator(at)comcast.net> wrote:
  After returning home from OSH, I noticed a chunck missing from my RV-10 nose wheel fairing.  When flexed, the fairing ripped as shown in this photo:
  I was surprised at how fragile the fairing was once that rip started.  With very little force I could have ripped the whole fairing into two pieces.
  I patched the missing chunk and rip, then added a few layers of fiberglass and epoxy resin, about 5" wide, to strengthen the entire circumference of the fairing forward of the bulkhead.   I also added a 1" wide reinforcement around the opening for the wheel:
  I recommend builders consider adding reinforcement in this area of the fairing during construction.
				 Posted: Sat Aug 11, 2012 9:16 am    Post subject: Nose wheel fairing breaks |
				Yep - mine ripped the same way while wrestling with it on fit up.  Put two
 layers of carbon fiber on the inside, ground out what was left of the crack,
 filled the void with flox, sanded smooth and then a couple of layers of
 glass on the outside.  Finish with mico.
 Carl
 33.6 hours - first O2 flight earlier today.
				 Posted: Sat Aug 11, 2012 1:18 pm    Post subject: Nose wheel fairing breaks |
				I didn't reinforce mine.  Haven't had any breakage yet operating out of
 a relatively rough grass strip.
 I did make it a point to cut them  back further than I wanted to... then
 a bit more.  Since I have them off the plane right now, I may try to
 compare with your pics to see if I can compare them.
 Reinforcement sounds like a good thing.
 Bill "finishing up my first condition inspection" Watson
 On 8/11/2012 10:23 AM, Tim Lewis wrote:
  this photo:
  pieces.
		partner14
				 Posted: Sat Aug 11, 2012 6:49 pm    Post subject: Nose wheel fairing breaks |
				One other thing to consider... I think when it comes time to buy new tires, almost all replacements (Goodyear Flt Custom III's for example) are larger than the original Van's supplied tire..... changes the clearance.  Without enough clearance, all you need is a low tire, or a rather big bounce, and you now have another project.
 Don McDonald
 470 Hours and climbing.
   From: Carl Froehlich <carl.froehlich(at)verizon.net>
  Sent: Saturday, August 11, 2012 12:14 PM
  Subject: RE: RV10-List: Nose wheel fairing breaks
  --> RV10-List message posted by: "Carl Froehlich" <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)>
 Carl
40636 |
		Kelly McMullen
				 Posted: Sat Aug 11, 2012 7:38 pm    Post subject: Nose wheel fairing breaks |
				That can be avoided by not buying the most expensive tire on the
 market. One can get equal life out of recaps, and they are more likely
 to meet the standard tire size. Or you can buy Condors if you prefer
 new, and they will be significantly lighter and slimmer than the FC
 III, which is the biggest and heaviest tire for a given nominal size
 you will find on the market.
 On Sat, Aug 11, 2012 at 7:49 PM, Don McDonald
 <building_partner(at)yahoo.com> wrote:
 [quote] One other thing to consider... I think when it comes time to buy new tires,
  Don McDonald
  Subject: RE: Nose wheel fairing breaks
  Carl
A&P/IA, EAA Tech Counselor
KCHD |
		amekler
				 Posted: Sun Aug 12, 2012 2:07 am    Post subject: Nose wheel fairing breaks |
				Yes a low tire pressure caused my fairing to crack.
 Alan
 > Don McDonald
 > To: rv10-list(at)matronics.com
 > Carl
				 Posted: Sun Aug 12, 2012 8:00 am    Post subject: Nose wheel fairing breaks |
				Some data points:
 - distance from lower bracket holes and edge of wheel cutout - 1 3/8"
 - distance from rear edge of wheel cutout and bulkhead - 1/2"
 Bill
 On 8/11/2012 5:17 PM, Bill Watson wrote:
  of a relatively rough grass strip.
  then a bit more.  Since I have them off the plane right now, I may try
  to compare with your pics to see if I can compare them.
 > in this photo:
  Checked by AVG - www.avg.com
