seat belts
carlossa52(at)gmail.com
PostPosted: Sat Jul 28, 2012 3:39 pm    Post subject: seat belts Reply with quote
Hello, allI need to order seat belts, and would appreciate your suggestions. I found this document explaining the installation of a harness manufactures by Crow Enterprizes (with a "z") that seems interesting. http://www.crowenterprizes.com/Pages/DriverRestraints.htmlIn particular, this one (part number 20114) http://www.parts123.com/parts123/yb.dll?parta~partsort~A2~cadeikca What is the preferred lock, the "latch and link" or "cam lock"? Thoughts, recommendations, suggestions?Thanks for you consideration CarlosCh601-HD, plans No longer a stack of parts [quote][b]
Ron Lendon
PostPosted: Mon Jul 30, 2012 5:17 pm    Post subject: Re: seat belts Reply with quote
A good four point system is what I have. It holds me in the seat with the standard three bolts, one on each side and the double shoulder harness is attached at one point at the back longeron.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
PostPosted: Mon Jul 30, 2012 6:24 pm    Post subject: seat belts Reply with quote
Hello, RonThat's the type of set up I am thinking of. What type of latch do you have?Thanks for your comments Carlos
On 30 July 2012 21:17, Ron Lendon <ron.lendon(at)gmail.com (ron.lendon(at)gmail.com)> wrote:
[quote]--> Zenith-List message posted by: "Ron Lendon" <ron.lendon(at)gmail.com (ron.lendon(at)gmail.com)>
A good four point system is what I have. �It holds me in the seat with the standard three bolts, one on each side and the double shoulder harness is attached at one point at the back longeron.
Ron Lendon, Detroit, MI
CH 601 XLB
N601LT
