frans(at)privatepilots.nl Guest
Posted: Fri Aug 10, 2012 1:01 am Post subject: Mod 77 |
Hi,
I just completed mod 77 (rudder drive mechanism). I was surprised to
learn that I'm the first one to apply it to a finished airplane. Here is
a couple of reasons why you could do this mod:
1) Your built has long finished and you want to retaste that nostalgic
feeling? Mod 77 has it all: Some hardware assembly with rivets,
bearings, nuts and bolts, some foam carving, floxing and BIDding, and
plenty of "I can see it, I can touch it, but not at the same time"
deja-vu's, and last but not least the occasional confusion (text and
pictures both showing different rivets, parts in the bag that are not
listed or used in the project at all). It is the entire built of your
ship in a nutshell.
2) If you, like me, have the weight of your feet resting on the rudder
pedals, consider that it is the lower rudder hinge which is carrying all
this weight, and it is even offset this pulling force. Mod 77 takes all
weight from this hinge and transfers only the differential weight of
your feet to the rudder.
3) The original rudder stop works as a lever mechanism to execute a
massive pulling force on the hinge, especially if slammed to the
starboard side. Mod 77 removes the stops from the rudder and instead has
it incorporated inside the drive mechanism with much more robust parts.
4) Always had this feeling that this control wire running outside of
your ship belongs more on a piper cub than on your sleek Europa? Mod 77
eliminates this control wire, horns and stops and improves the cosmetics
of your ship.
5) This outside control horn and wire seemed to capture all the mud and
grass that the prop and wheels are slinging to this area, and then the
control wire did its best to draw it into the wire opening in the
fuselage, waiting there to jam or freeze itself stuck. Mod 77 reduces
maintenance quite a bit, the entire rudder drive is now inside the ship.
6) The control wire, control horn angled in the airstream, stops, and
rudder bottom cut-off, must create quite some aerodynamic drag. Mod 77
removes all this clutter and as a bonus you can blend in the bottom of
the rudder with the bottom of the tailpost. Probably woth a knot or two.
Oh, for those concerned about weight: The components weigh about 500
grams. But I could remove a good 350 grams of old hardware. Remember the
absurd weight of the original rudder plate, the stacks of washers, etc?
Frans
craigb(at)onthenet.com.au Guest
Posted: Fri Aug 10, 2012 1:19 am Post subject: Mod 77 |
Did mine during the build, but it was still fun and games, probably not as
much as yours though
Posted: Fri Aug 10, 2012 2:46 am Post subject: Mod 77 |
Frans
When I first developed this mod I had to load test it for the LAA. Because of the leverage of the rudder pedals (and our strong legs)
If one pilot pushes hard left and the other one has to overide him the total load on the hing and flange would be nearly 400 Kg.
7 years ago we sold our house and with it went my wonderful workshop . That meant I had to stop making up Mod kits so I persuaded
David Stanbridge that it would be a good idea for Europa to sell this mod. It works for taildraggers too btw,
We flew my Long EZ last week for the first time in too many years, it felt wonderful. I am tempted to revalidate my lisence and fly it from the front again!
Graham
Sent: Friday, 10 August 2012, 10:53
Subject: Mod 77
--> Europa-List message posted by: Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)>
Hi,
ship in a nutshell.
of your ship.
absurd weight of the original rudder plate, ics.com/Navigator?Europa-List" ="http://forums.matronics.com/" target="_blank">http://forums.matronics  tronics.com/contribution" target="_blank">http://www.matronics.com/contri================
Posted: Fri Aug 10, 2012 3:20 am Post subject: Mod 77 |
Hi Graham!
| Quote: | Because of the leverage of the rudder pedals (and our strong legs)
Wow! I didn't even think about an override and the leverage! 400Kg is a
lot for that poor hinge! Which brings up the question why the standard
construction is even certified... Or why this mod didn't get
incorporated in the standard kit long time ago.
| Quote: | 7 years ago we sold our house and with it went my wonderful workshop:-S
I even don't want to think about loosing my workshop...
| Quote: | That meant I had to stop making up Mod kits so I persuaded
mod.
Just putting the mod somewhere burried onto the website isn't going to
attract many customers... It took a while before I discovered its
existence, and it took me a while to realize the benefits of this mod.
| Quote: | We flew my Long EZ last week for the first time in too many years, it
the front again!
I think as a relatively newcomer I miss some history here. So you built
a long EZ?
Thanks for inventing this mod 77.
Frans
Posted: Fri Aug 10, 2012 3:44 am Post subject: Mod 77 |
Frans
The Long EZ was the first aircraft I built, or at least the first model airplane big enough to sit in! First flew
1985 and wore out the engine in the next ten years. I've been refurbishing and upgrading ever since.
Ivan Shaw was a very early Rutan disciple and helped me get started, there were four of us building at
the time and we used to meet up in the hills, drink beer and talk about the next great design. The goal was an airplane that would have
Long EZ performance and short field capability and the Europa was Ivan's distillation of all our dreams and ideas.
I claim credit for demanding it should be deriggable in 15 minutes like any self respecting glider. Ivan was persuaded to
visit one of my local gliding clubs and see how they carry on. He always recognises a good idea when he sees one.
Notice the similarity of the tailplane to that of a K6E?
Graham
Sent: Friday, 10 August 2012, 13:12
Subject: Re: Mod 77
Hi Graham!
mod.
the front again!
a long EZ?
Thanks for inventi========================http://forums.matronics  tronics.com/contribution" target="_blank">http://www.matronics.com/contri================
klinefelter.kevin(at)gmai Guest
Posted: Fri Aug 10, 2012 5:20 am Post subject: Mod 77 |
Hi Pete,
How might we access this report?
Kevin
On Aug 10, 2012, at 4:44 AM, Peter Zutrauen <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)> wrote:
[quote]Frans (and other newer members),
you may may want to read the great report of Ivan's presentation at the last AGM in the last newsletter - what a great read! Quite the history lesson (with Graham's contribution included I believe).
Pete
A239
On Fri, Aug 10, 2012 at 8:12 AM, Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)> wrote:
| Quote: | --> Europa-List message posted by: Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)>
Hi Graham!
> mod.
> the front again!
a long EZ?
Frans
target="_blank">http://www.matronics.com/Navigator?Europa-List
le, List Admin.
stephen vestuti
Posted: Fri Aug 10, 2012 8:52 am Post subject: Re: Mod 77 |
Graham,
I let my license lapse in 2010, ( kids, wife, spending too much money on
myself Etc.) I revalidated 6 Months later - I couldn't stand it any more &
I was missing my Europa more & more everyday.
I hope to hear that you have flown your long Ez from the front, life is just too short .
Steve #630
steven.pitt2(at)ntlworld. Guest
Posted: Fri Aug 10, 2012 10:45 pm Post subject: Mod 77 |
Kevin,
As a Member of the Europa Club you should be receiving the Europa Flyer in which is contained the report on Ivan's presentation ( as well as a fantastic photo montage of Flying to Kitty Hawk by Troy and Donna Maynor).
I have been trying to persuade our Treasurer (who shot a video of the presentation) to get it on You Tube or whatever but he has a Europa to build (which we keep on nagging him to finish)so he is finding time difficult to edit the video.
Steve Pitt
Chairman, Europa Club
g-iani(at)ntlworld.com Guest
Posted: Sat Aug 11, 2012 12:54 am Post subject: Mod 77 |
Frans
How about an article for the Europa Flyer? It would be nice to know how you
achieved the near impossible ("I can see it, I can touch it, but not at the
same time") installation of the bell-crank assembly in a completed aircraft.
If it seems possible for normal mortals (not Dutch) I can add it to the
instructions.
I need all the help I can get to get the documentation right (as no one at
Europa can help).
The parts list, on pages 1 & 2, should be correct so please let me know if
you have spotted any errors. Any other parts supplied in error needs
reporting back to Europa.
As you say the rivets supplied would have been TLPD435BS. Apologies, I
missed the reference in section 3.6 to the original (AN470-AD4-10) rivets
which they replace. This change was made as few builders have rivet punches
to form nice heads on solid rivets.
I have already added a reference to refinishing the base of the rudder to
the latest revision.
Best wishes
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
Posted: Sat Aug 11, 2012 1:56 am Post subject: Mod 77 |
Steve
Maybe we should start a countdown for Nigel's lift off?!?!
How long is it now, almost as long as it took me to refurbish my EZ!
Graham
Sent: Saturday, 11 August 2012, 7:44
Subject: Re: Mod 77
Kevin,
Steve Pitt
peterz(at)zutrasoft.com Guest
Posted: Sat Aug 11, 2012 3:48 am Post subject: Mod 77 |
I for one would really love to Watch that video! YouTube would be fantastic!
Cheers, and if it goes up, many thanks!
Pete
a239
On Aug 11, 2012, at 2:44 AM, "Steven Pitt" <steven.pitt2(at)ntlworld.com (steven.pitt2(at)ntlworld.com)> wrote:
[quote] Kevin,
Steve Pitt
Posted: Sun Aug 19, 2012 6:32 am Post subject: Mod 77 |
Ian,
On 08/11/2012 10:52 AM, G-IANI wrote:
| Quote: | How about an article for the Europa Flyer? It would be nice to know how you
That would not be too much trouble, but I didn't make any pictures of
the installation.
| Quote: | If it seems possible for normal mortals (not Dutch) I can add it to the
instructions.
One very important thing: I had already installed a vent opening in the
sternpost to receive a 2" scat hose connected to the cabin. I made this
connector removable with 3 anchor nuts in the flange. This 2" opening in
the sternpost appeared to be handy for many things; if I ever wanted to
take the elevator push rod out I could do it via this opening, but it is
also handy for visual inspection of the tunnel from the rear of the
ship, it just adds another angle to look at things. Now it came in handy
for installation of mod 77. For the most part I could use it as a peek
hole while working through the standard hatch, and I also used it to get
a flexible drill extension in to drill the required holes.
Because I think it is impossible to do mod 77 without such an opening in
the sternpost I would propose to create this opening first. You could
install it at the approximate height where the push rod for the rudder
will pass through, and later put a cover on the opening with a hole in
it for the push rod. This way it is also much easier to determine where
exactly the opening for the push rod should be. And if you are not happy
with the result you just make a new cover; instead if you have to make
the hole in the sternpost you only have one shot at it and it will
likely end up larger than necessary.
| Quote: | The parts list, on pages 1& 2, should be correct so please let me know if
The confusion was mainly on part of the rivets. Not only in the docs but
I also received a confusing set of rivets, including the dreaded
AN470-AD4-10's. I also received too many cotter pins, too many cable
ends, 4 very long AN525 bolts for no purpose. Oh and there is no mention
in the document about the connection of the rudder end of the push rod.
I received an EUR001 safety washer for it, the manual says to attach it
similar as the other end, but as the rudder end has two lips instead of
one the eye-bolt can't go anywhere anyway. I just put some AN416L
washers on both ends between the lips.
I would also like to see a different way to attach the push rod to the
rudder, as it is very difficult to tighten the nut on the AN4-bolt via
the rudder gap. Maybe just a bolt with a cotter pin through it would do?
Anyway, you can't access it with a normal socket, and with a spanner the
clearance is not enough to make a sufficient turn. I ended up using two
ratcheting spanners but just one "click" is all I can get, so it takes
hours to tighten the nut. (And no, you can't connect the push rod to the
rudder first, as there is no way you can handle two spanners through the
hatch to tighten the other end afterwards (I can get only one hand in it
at the same time). Now I think of it: Maybe an anchor nut on that metal
plate would make things easier, instead of the nut and bolt.
Oh, and I discovered that the push rod is just as heavy as the rest of
the assembly. Is there a reason why this is from steel instead of
aluminium? We used aluminium for all the other controls in the ship (it
looks like the aileron push rod is the same diameter but then in
aluminium), so why has this one to be from heavy steel?
| Quote: | I have already added a reference to refinishing the base of the rudder to
Great!
Frans
Posted: Wed Aug 29, 2012 2:25 am Post subject: Mod 77 |
Frans
Apologies for not replying earlier to your reply of 19/08. Andy Draper has
had a sudden attack of needing to tidy up some of the paperwork. The result
is a new Standard Mod (for the Andair fuel selector) and the Fuel Flow SM
updated for the FT-60 (Red cube) flow sensor. Not much use if you know what
you are doing but it makes the upgrades legal in the UK.
I think it is worth saying that on Mod 77 I inherited a partially
undocumented mess. Graham sold Mod 77 to David Stanbridge who then
announced it as available. The fact that nobody at Europa had ever seen one
(never mind built one) seems to have escaped David's notice.
I think the bill of materials [BOM] used when you got your parts was the old
one. I have checked with Europa and they are now using the new one included
in the document.
| Quote: | > One very important thing: I had already installed a vent opening in the
sternpost <<
Yes as I have on G-IANI. The pictures were taken on G-IRON which was being
rebuilt so the hole was not needed. I will add a reference to adding this
hole for a retro fit. If time permits I may do Mod 77 on G-IANI this winter
and can photograph the work.
| Quote: | > Oh and there is no mention in the document about the connection of the
rudder end of the push rod.<<.
There is (see section 3.7) but it is easy to miss
| Quote: | >I received an EUR001 safety washer for it, the manual says to attach it
similar as the other end, but as the rudder end has two lips instead of one
the eye-bolt can't go anywhere anyway. I just put some AN416L washers on
both ends between the lips.<<
You are right I will try and make this clearer.
| Quote: | >I would also like to see a different way to attach the push rod to the
rudder, as it is very difficult to tighten the nut on the AN4-bolt via the
ratcheting spanners but just one "click" is all I can get, so it takes hours
to tighten the nut. (And no, you can't connect the push rod to the rudder
first, as there is no way you can handle two spanners through the hatch to
tighten the other end afterwards (I can get only one hand in it at the same
time). Now I think of it: Maybe an anchor nut on that metal plate would make
things easier, instead of the nut and bolt.<<
I think I prefer the idea of using an anchor nut on the CS33.
| Quote: | >Is there a reason why this is from steel instead of aluminium? We used
aluminium for all the other controls in the ship (it looks like the aileron
push rod is the same diameter but then in aluminium), so why has this one to
be from heavy steel?<<
I think it is just history and people being conservative. It is 100 grams
heavier than the Al tube of this length. The forces on this rod are
considerably higher than on the aileron rod and a structural engineer will
need to convince the LAA that the Al tube would not bend.
We make progress slowly
