BobbyPaulk(at)comcast.net Guest
Posted: Fri Aug 10, 2012 5:48 am Post subject: Spark plug adaptor |
List
I took one of my old spark plugs and broke off the porcelain ( be sure to cover it with a rag ), cut off the upper portion, gutted it and brazed a 1/4" x 4" pipe nipple onto it. Get a threaded air quick disconnect fitting to match your hose and you are in business.
Bobby
Lynn Matteson
Posted: Fri Aug 10, 2012 6:11 am Post subject: Spark plug adaptor |
In the original post, Dennis said:
"And no, I'm not interested in building one out of an old spark
plug. Although it would work fine, I don't have the torch to braze
on the fitting."
He may have secured his adapter by now, but for anybody else who
might be interested, silver soldering/silver brazing is a very good
way to achieve the same results, and can be done with a small propane
torch, not necessarily a welding torch....and it's a MUCH cleaner job
than brazing/welding.
I made mine like you did, Bobby, but silver soldered the quick
disconnect directly to the spark plug base, eliminating the pipe
nipple altogether.
Lynn Matteson
Jabiru 2200, #2062
Prince prop 64 x 30, P-tip
Rotec TBI-40 injection (sleeved to 36mm)
Status: flying with 1324 hrs... (since 3-27-2006)
On Aug 10, 2012, at 9:48 AM, BobbyPaulk(at)comcast.net wrote:
| Quote: | List
Bobby
============================================================ _-
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
dwwilt
Posted: Fri Aug 10, 2012 6:23 am Post subject: Spark plug adaptor |
Yes, I have purchased an adaper from Lockwood Aviation. Price - $16.40 plus shipping. The adapter is in their catalog, but not searchable on their website.
Have a wonderful day,
Dennis
N616DW (Arion Lightning S/N 132)
_________________ Dennis |
Posted: Sat Aug 11, 2012 5:14 am Post subject: Spark Plug adaptor |
List
For those without a torch!
I found out that J-B Weld does a good job of attaching a pipe nipple or hose adapter to an old spark plug to make the Compression Adapter.
Bobby
