Posted: Sat Aug 11, 2012 4:26 am Post subject: Attaching "uninsulated ring terminals" to 4 awg wire... |
At 09:30 PM 8/10/2012, you wrote:
I'm using the "uninsulated ring terminals" for 4 awg wire from the
contractors to my bus and alternator. Are the terminals sold by B&C
meant to be crimped or soldered? If crimped where can I get a
crimper big enough to handle 4 awg. B&C only sells ones that handle
up to 10 awg wire.
Michael-
Crimp tools for the larger terminals are
pretty pricey. Further, most airplanes will
need only a handful of large terminals. Consider
soldering un-insulated terminals and dressing
out with heat shrink. See:
http://tinyurl.com/9pbvky8
Posted: Sat Aug 11, 2012 4:30 am Post subject: Attaching "uninsulated ring terminals" to 4 awg wire... |
At 06:05 AM 8/11/2012, you wrote:
I've got one of those wack-types that I'd like to get rid of. I
wasn't happy with the results, but perhaps someone else coudl do
better. I anyone is in the market for one, send me a note.
The problem with beat-n-bash crimpers is lack
of verification for having achieved a gas-tight
joint.
See:
http://tinyurl.com/8vk6sxc
http://tinyurl.com/93yweyd
Without vetting the marriage of wire-to-terminal-to-tool,
the easiest way to maximize copper in the wire grip is
to stuff wire-wedges into the matrix and then fill all
voids with free-flow of an electronic grade 63/37 solder.
Works good, lasts a long time.
