				 Posted: Thu Aug 09, 2012 7:27 am    Post subject: SS7 Tail Spring Width/ Install Question |
				I'm trying to install my tail springs (3) on my SS7.  The width of the springs is greater than the distance between the bolts/spacers to get the bolts in the spring plate to line up with the holes in the fuse.
 Solutions I see;
 - machine down spacers (probably the best solution)
 - enlarge holes in fuse and spring plate
 - grind down width of spring (and of course polish out).
 Just wondering if others had this issue and how they resolved.
 -Mike Kraus
 SS7, just getting started!
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		sourdostan(at)aol.com Guest
				 Posted: Thu Aug 09, 2012 8:52 am    Post subject: SS7 Tail Spring Width/ Install Question |
				First thing I'd do is call the factory.
   Stan Specht
		7suds(at)Chartermi.net Guest
				 Posted: Thu Aug 09, 2012 1:12 pm    Post subject: SS7 Tail Spring Width/ Install Question |
				Mike,
 I agree with Stan, call John at Kitfox and see what he suggests, whatever
 you end up doing in the end you will want to make sure the spring is not
 able to slide side to side after bolted or you may have some difficulty with
 ground handling.
				 Posted: Thu Aug 09, 2012 2:11 pm    Post subject: SS7 Tail Spring Width/ Install Question |
				I emailed John, he recommended turning the bushings down.
 On Aug 9, 2012, at 5:11 PM, "Lloyd & Lorrie Cudnohufsky" <7suds(at)Chartermi.net> wrote:
  Mike,
  ground handling.
