Posted: Thu Aug 16, 2012 8:05 pm Post subject: Should battery be charged with a higher voltage? |
Quote: |
Have I come to the correct conclusion about the regulator setting?
Joe
Yes. A SVLA battery will always charge to 100% of capacity
with a 13.6 to 13.8 volt bus. The reason bus voltages are
set higher is to shorten a cycle time for recharge after
a deep discharge.
But if you always take off with a very lightly taxed
battery then the lower set point is fine.
user9253
Joined: 28 Mar 2008 Posts: 1942 Location: Riley TWP Michigan
Posted: Fri Aug 17, 2012 1:50 am Post subject: Re: Should battery be charged with a higher voltage? |
Bob, Thanks for your words of wisdom.
To Ron P,
I could not find any reference to a diode on EuropaOwners.org. But I assume that the diode is inserted in the regulator sense wire. I had thought about doing that, but voltage measurements indicate that my battery is kept fully charged with the 13.6 volt regulator set-point.
The charging instructions in the Oddyssey manual
http://www.odysseybatteries.com/files/US-ODY-TM-001_0411_000.pdf
pertain to a discharged battery. Since my PC680 battery never gets discharged, the Continuous Float Charge voltage of 13.6 is adequate.
I appreciate your input.
Joe
_________________ Joe Gores |
