VE3LVO(at)rac.ca Guest
Posted: Fri Jun 02, 2006 5:14 am Post subject: Firewall penetration |
I followed the trail to the site of the penetration kits at EPM wherein the
sealant is referred to as "Biotherm 100 silicone fireblock sealant."
Since I wanted to use a similar material for other penetrations, I attempted
to further search the net for the subject sealant. there is no source other
than EPM, so am not sure of its specifications.
Any clues out there?
Ferg Kyle
Europa A064 914 Classic
nuckollsr(at)cox.net Guest
Posted: Fri Jun 02, 2006 6:04 am Post subject: Firewall penetration |
At 09:08 AM 6/2/2006 -0400, you wrote:
This putty is used in a VERY thin interface between firewall
and the flange of the fitting. Any fire-retarding material
(from plumbing and/or electrical supplies section of well
stocked hardware store) will do.
rvbuilder(at)sausen.net Guest
Posted: Fri Jun 02, 2006 7:00 am Post subject: Firewall penetration |
Fire rated sealants are now very common at your local Lowes Depot as it =
is now required by code for many household construction penetrations. =
Save yourself some time and money and use one of those. I'm using an =
Intumescent fire barrier caulk for sealing penetrations which actually =
expands and regenerates the barrier as it is hit by flame and crumbles. =
Very tough stuff, stays flexible, and rated for 4 hour contact.
Michael Sausen
RV-10 #352 Working on Fuselage
Jerry Grimmonpre'
Joined: 09 Jan 2006 Posts: 144 Location: Huntley, Illinois 60142
Posted: Fri Jun 02, 2006 7:34 am Post subject: Firewall penetration |
Michael ...
Where did you get your intumescent fire barrier caulk and is there a part
number?
Thanks ...
Jerry Grimmonpre'
RV8A Electric
Posted: Fri Jun 02, 2006 9:05 am Post subject: Firewall penetration |
I have some of their kits but have not installed them yet. So I went out to
look at the tubes of sealant. Unfortunately they are blank white tubes. In
searching with Google I found this in the Aeroelectric archives in a message
from David Carter on Dec 4th, 2003:
"Wonderful product (epm.av's) that mimicks Bob's home grown grab bar
solution
and adds the 2000 degree "Biotherm 100 silicone fireblock sealant" to dress
the end of "fire sleeve stuffed sleeve of fire sleeve".
I just called and they buy the VERY expensive sealant and repackage into 1.5
oz doses to sell with the kits."
Me, I would just use RTV - I have turned a blowtorch on it for minutes and
seen no effect.
-- Craig
Posted: Fri Jun 02, 2006 9:55 am Post subject: Firewall penetration |
Home depot in the caulk section. Specifically it is 3M Fire Barrier =
Sealant CP25WB. Anything that is rated for through penetration void =
sealing in construction should be fine but the Intumescent is generally =
considered the best.
Hope this helps.
Michael Sausen
Gilles.Thesee(at)ac-greno Guest
Posted: Fri Jun 02, 2006 12:30 pm Post subject: Firewall penetration |
Hi all,
I've used 3M Fire Barrier 2000 with success.
Concerning firewall penetration :
http://contrails.free.fr/engine_cpf.php
Gilles Thesee
Grenoble, France
brinker(at)cox-internet.c Guest
Posted: Fri Jun 02, 2006 1:16 pm Post subject: Firewall penetration |
Sorry I don't read French and too lazy to use Babelfish. But I do
enjoy looking at pictures and if I am understanding your pic's correctly it
looks as though you are using industrial type electrical connectors for the
penetration and just sealing with high temp 3m and a fire sleeve. Which I
don't see why it would not work. Even if the connectors are just galvanized
steel and not stainless.
Randy
Posted: Fri Jun 02, 2006 1:33 pm Post subject: Firewall penetration |
| Quote: | if I am understanding your pic's correctly it
Randy,
My web page is divided into 4 parts :
- Roles of the firewall
- What's NOT to be done (IMHO) : rubber grommet, putty patch...
- What I did : home made STAINLESS steel penetrations
- What others do : brass fittings, Bob's method, grommet shields, EPM.AV
Corp' fittings
You may really wish to use Google translator, after all )
Gilles Thesee
Grenoble, France
Posted: Sat Jun 03, 2006 5:53 am Post subject: Firewall penetration |
Just updated the "Firewall" page with some compound examples and pictures :
Only in French for some time, I'm afraid ;-(
Gilles Thesee
Grenoble, France
Posted: Sat Jun 03, 2006 8:44 am Post subject: Firewall penetration |
Could not get Google translator to work on your website, it could
not find it (: Although Babelfish came through for me the translation leaves
somewhat to be desired. Nice site though and informative. Thanks for the
info.
Randy
