Kelly McMullen
Posted: Mon Aug 20, 2012 3:20 am Post subject: Shudder/shimmy on landing/ brakes/tires and other stuff I w |
Sean,
You can correct the brake caliper problem, no need for new hardware.
You can find some brake silicone lube at any National Aircraft Parts
Assn store (aka NAPA0 or equivalent. Lube the pins(and nothing else).
If you have 5606 fluid in your brake system and any seeped out at the
caliper that can also cause it to stick, as well as being fire hazard.
Good excuse to change the system over to the better high temperature
fluid.
Kelly
On Sun, Aug 19, 2012 at 8:26 PM, Seano <sean(at)braunandco.com> wrote:
| Quote: | Also started to get some brake drag on the left caliper. Noticed the slop
on the pins and a little rubbing on the caliper from the edge of the rotor.
Anyone else notice this?
I may talk to Matco about aftermarket brake parts.
A&P/IA, EAA Tech Counselor
KCHD |
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Mon Aug 20, 2012 3:38 am Post subject: Shudder/shimmy on landing/ brakes/tires and other stuff I w |
Thanks Kelly,
I've been using Royco 782 as the fluid with the Viton O-rings from the
start.
I will try the lube and install the new pads.
Seems like a lubed them last inspection in January.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
