stephen vestuti
Posted: Tue Aug 21, 2012 4:19 am Post subject: Fuel Gauge |
Hi,
I've cut out the fuel tank for the factory Werner fuel gauge,
it comes with a rubber gasket but I'm not happy with it sealing around the
five AN bolts, what can be used as a sealant for the gauge ?, I Know I can use
redux as a last resort,
Steve , Europa No. 630
gholland(at)content-strea Guest
Posted: Tue Aug 21, 2012 5:41 am Post subject: Fuel Gauge |
Steve Hi!
I remember using some stuff from ACS called PTS PROSEAL 890-CLASS B-TYPE I
One downside. It seems to cost around $75 now, probably £75 if you ordered through LAS.
I used it to seal all fuel system connections and it was particularly good on capacitive fuel sender gaskets and the fuel filler connections.
Gerry
rowlandcarson(at)gmail.co Guest
Posted: Tue Aug 21, 2012 7:49 am Post subject: Fuel Gauge |
On 21 Aug 2012, at 13:19, stephen vestuti wrote:
| Quote: | I've cut out the fuel tank for the factory Werner fuel gauge,
Steve - on advice from Brian Fogg who found it was the final answer to the fuel smell from his level sender, I used Loctite 5922 to seal the flange of the factory fuel gauge sender to the tank . Brian got his from Halfords, but my local branch never had any on several tries, so I got mine from Grampian Fasteners.
<http://www.grampianfasteners.com/Products.aspx?cat=10914118>
Hope this helps.
in friendship
Rowland
| pictures: http://picasaweb.google.com/rowlandcarson
stephen vestuti
Posted: Tue Aug 21, 2012 10:34 am Post subject: Re: Fuel Gauge |
Hi All,
What about the Gasket ?, I'm thinking of scrapping it and using one of those
sealants to bond the flange directly to the top of the fuel tank - did any of
you scrap the gaskets ?
Steve Europe No. 630
jeff(at)rmmm.net Guest
Posted: Tue Aug 21, 2012 10:48 am Post subject: Fuel Gauge |
I used just the gasket then one day when I filled the tank all the way up it leaked everywhere. I added pro seal on both sides of the gasket which was the messiest job ever and it has't leaked since.
Jeff R. N128LJ Gold Rush
On Aug 21, 2012, at 1:34 PM, stephen vestuti wrote:
Hi All,
http://forums.matronics.com/viewtopic.php?p=381470#381470
Posted: Tue Aug 21, 2012 11:33 am Post subject: Fuel Gauge |
On 21 Aug 2012, at 19:34, stephen vestuti wrote:
| Quote: | What about the Gasket ?, I'm thinking of scrapping it and using one of those
Steve - why discard the gasket? I saw no reason to do so. It must provide a better seal to the slightly-flexible tank than the metal flange would by itself.
in friendship
Rowland
stephen vestuti
Posted: Wed Aug 22, 2012 1:22 am Post subject: Re: Fuel Gauge |
Thanks for the feedback, I'll keep the gasket then.
I've spoken to Light Aero , and they say that this is resistant to
Mogas http://www.lasaero.com/site/products/article?id=D02VK9NTH ,
I'll give it a try,
Steve, Europa # 630
