ELT Antenna
Goto page 1, 2  Next
Kelly McMullen
PostPosted: Tue Aug 28, 2012 8:43 am    Post subject: ELT Antenna Reply with quote
I am looking at installing my ACK E-04 antenna under the tail
intersection fiberglass fairing. I've read through a good discussion
on the AeroElectric list and feel the trade-off of horizontal
polarization, vs protection from impact and eliminating the drag is
worth it. I know that Mooney got approval for similar antenna instal
for a 406 antenna in fiberglass ventral fin.
My question is if anyone has done this and gotten any grief from their
DAR. My only concern is to fully meet the TSO on the ELT you are
supposed to comply with the install instructions, that call for
vertical mounting withing 30 degrees.
Kelly
40866
forever finishing
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Strasnuts
PostPosted: Tue Aug 28, 2012 8:49 am    Post subject: ELT Antenna Reply with quote
Kelly,
I mounted mine horizontally under the tailcone fairing with no problems from
the DAR.
I later converted mine to 406 and accidentally set it off. The airforce
called me within 5 minutes so I knew it worked well even in the hangar with
the door closed. I wouldn't recommend testing it this way Smile
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
rene(at)felker.com
PostPosted: Tue Aug 28, 2012 8:52 am    Post subject: ELT Antenna Reply with quote
That is how I did it. My DAR did not comment.
After the crash, which way will the antenna be pointing?
Rene' Felker
N423CF
801-721-6080
jesse(at)saintaviation.co
PostPosted: Tue Aug 28, 2012 8:54 am    Post subject: ELT Antenna Reply with quote
I've done it and haven't gotten any grief from a DAR.
Kelly
40866
forever finishing
Strasnuts
PostPosted: Tue Aug 28, 2012 8:56 am    Post subject: ELT Antenna Reply with quote
Ya. Plus in my checklist I state to make sure you crash within 30 degrees of vertical so they can find your body.
Rene' Felker
N423CF
801-721-6080
780 Hours
SuperSTOL 60 hours
coop85(at)verizon.net
PostPosted: Tue Aug 28, 2012 8:59 am    Post subject: ELT Antenna Reply with quote
Kelly,
That's exactly what I did and received no grief whatsoever from the DAR.
Marcus
Kelly
40866
forever finishing
rv10rob(at)gmail.com
PostPosted: Tue Aug 28, 2012 9:03 am    Post subject: ELT Antenna Reply with quote
I installed my 406 ELT on top of the tail cone, to ensure it has a good ground plane and view of the sky.  I really regret it.  It looks dumb and is draggy.  By all accounts, they work great under the tail fairing, and for me flying most trips IFR and using a SPOT mitigates the risk even further.
-Rob
On Tue, Aug 28, 2012 at 9:56 AM, Seano <sean(at)braunandco.com (sean(at)braunandco.com)> wrote:
[quote] --> RV10-List message posted by: Seano <sean(at)braunandco.com (sean(at)braunandco.com)>
On Aug 28, 2012, at 12:48, "Rene Felker" <rene(at)felker.com (rene(at)felker.com)> wrote:
> --> RV10-List message posted by: "Rene Felker" <rene(at)felker.com (rene(at)felker.com)>
> Rene' Felker
> N423CF
> [url=tel:801-721-6080]801-721-6080[/url]
carl.froehlich(at)verizon
PostPosted: Tue Aug 28, 2012 10:06 am    Post subject: ELT Antenna Reply with quote
That is how I have the antenna mounted in both the 8A and the 10. The local FSDO did sign offs on both planes and did not mention the mount for either one.
Carl
On Aug 28, 2012, at 12:53 PM, Jesse Saint <jesse(at)saintaviation.com> wrote:
> Kelly
> 40866
> forever finishing
rv10pro(at)gmail.com
PostPosted: Tue Aug 28, 2012 10:53 am    Post subject: ELT Antenna Reply with quote
Use an IFR-4000-Opt 1 and see if the 406 emits the squitter discrete data from your concealed antenna.  It will also allow you to determine how many Db loss the idea cost.
We have the elt mounted with horizontal ground plane and 1/3 of the antennae concealed.  It is a quarter wave for 121.5.
Cosmetics goes out the window when you are inverted in the snow in February.  The drag coefficient has always been a none issue.
John On Aug 28, 2012 9:46 AM, "Kelly McMullen" <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:[quote] --> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)>
Kelly
40866
forever finishing
http://forums.matronics.com
le, List Admin.
rnewman(at)tcwtech.com
PostPosted: Tue Aug 28, 2012 4:53 pm    Post subject: ELT Antenna Reply with quote
All of you that have not had an issue with your DAR inspection count yourself as lucky. My DAR had this issue of the ELT antenna being absolutely installed per the TSO for which the ELT was certified up front on his list of things that were deal breakers for him. This is the only antenna hole I had to drill through the top of my airplane, I was not pleased. The only good news for me was that he was upfront about the antenna issue and I had a month or so to prepare myself for drilling the hole.
good luck with your elt install, your experience will vary with the DAR available to you!
Bob Newman
N541RV
www.tcwtech.com
rv10flyer(at)verizon.net
PostPosted: Tue Aug 28, 2012 6:02 pm    Post subject: ELT Antenna Reply with quote
DAR are basically FAA designated representatives. I had to spend 3 hours at a FSDO with 7 different FAA examiners drilling me for my repairman’s certificate. Another builder got his after a 15 minute discussion with his FSDO and his explaining the pictures, difference is he went to a FSDO that understood experimental aircraft, I went to my FSDO in a area where they don’t see too many experimentals so they don’t understand the rules and requirements without studying the regs..
My point is my DAR has a RV has been a DAR for 21 years and knew the rules for “experimental” aircraft, he recommended I put the antenna where mine is, under the fiberglass fairing below the VS, he told me a whole lot because he knew what the rules were but he also knew what is was like to fly a RV. I wasn’t lucky, I was fortunate.
Get a Technical Councelor, get one that knows RV and who knows who the best DAR is for you. Having to drill a hole is ridiculous, I would have found another DAR if I was told this was my only option, if that 2nd opinion DAR told me to do it, than I would. I can’t tell you how many “highly educated” people told me I needed to do something, I tested the idea off of another builder who almost laughed at my questions, in the end he was right I didn’t need to drill holes in places to do the job right.
Sent: Tuesday, August 28, 2012 5:52 PM
Subject: Re: ELT Antenna
Bob Newman
N541RV
www.tcwtech.com
Bob Turner
PostPosted: Tue Aug 28, 2012 10:55 pm    Post subject: Re: ELT Antenna Reply with quote
Anyone mount their antenna to the baggage area bulkhead, with the antenna running just below the baggage area fiberglass ceiling?
Bob Turner
RV-10 QB
dave.saylor.aircrafters(a
PostPosted: Wed Aug 29, 2012 5:50 am    Post subject: ELT Antenna Reply with quote
Doesn't it need to be vertically polarized (pointing up, not horizontal)?
Mine is mounted on the back seat cross bar against the left side. I
figured the cross bar provides some ground plane, as does the rest of
the nearby sheet metal. Seems to work fine.
Dave Saylor
831-750-0284 CL
On Tue, Aug 28, 2012 at 11:55 PM, Bob Turner <bobturner(at)alum.rpi.edu> wrote:
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=382041#382041
cjhukill(at)cox.net
PostPosted: Wed Aug 29, 2012 6:15 am    Post subject: ELT antenna Reply with quote
I mounted my 406 ELT antenna using the baggage bulkhead as the ground plane and actually embedded wire of the antenna in the canopy cover, (as well as the GPS antenna). My RV8 has the ELT antenna in the wing tip, mounted horizontally, and that passed the AirForce operational test as well, in a closed metal hangar. The vertical mounting that is recommended (not required by the aircraft manufacturer), is to optimize the low power (100mw)121.5 MHz signal for the SAR to home in on. The horizontal polarization optimizes the much stronger (5 watt) 406 MHz signals getting to the satellites. As the aircraft manufacture, I prioritized the ability to get a signal up to a satellite rather than to the ground searchers. I did also leave in the old 5 Watt, 121.5 MHz ELT as well for those guys to practice with. Any DAR without the understanding of this technology or the rights and responsibilities of the aircraft builder will be eliminated as contenders for my choice for certification.
Chris Hukill
RV10 on hold while RV8 gets yet another new panel with ADS-B and Synthetic Vision.
Kellym
PostPosted: Wed Aug 29, 2012 6:19 am    Post subject: ELT Antenna Reply with quote
Optimal is vertically polarized when needed. IMHO, if you crash and
wind up in the same orientation as normal on the gear, you probably
don't need the ELT. Otherwise, in any other crash position, you probably
do need ELT, but I'm not smart enough to predict that position, much
less which way that would make vertical. One of the experts on the
AeroElectric list estimated that if you had horizontal orientation
instead of vertical you would lose about 3 db of signal strength.
I do like your idea as a potential location for the antenna that would
be out of the way, and technically meet the install instructions for
vertical orientation.
Kelly
Dave Saylor
831-750-0284 CL
> Bob Turner
> RV-10 QB
Checked by AVG - www.avg.com
Kelly McMullen
KCHD
Tim Olson
PostPosted: Wed Aug 29, 2012 6:35 am    Post subject: ELT Antenna Reply with quote
Personally, I'd agree with this. The one thing that people tend
to overlook though is that probably the MOST important thing
is that you maintain the integrity of the antenna to ELT box
connection. It won't matter much where the antenna is, if the
antenna cable is ripped away from the ELT because it was
mounted to some structure that tore away. So keeping the
antenna mounted either to the same structure or to something
very nearby or robust nearby would be best.
Kelly
Kelly McMullen
PostPosted: Wed Aug 29, 2012 6:49 am    Post subject: ELT Antenna Reply with quote
Very valid point Tim. I'm not sure that going through the baggage
compartment bulkhead would meet that criteria. On the other hand, I
don't want to mount the ELT all the way back in the tail cone where
only a 10 year old could get in and change the battery, nor do I
really want it in the cabin where a bag or pax could accidentally bump
it.
Kelly
Kelly McMullen
KCHD
PostPosted: Wed Aug 29, 2012 6:51 am    Post subject: ELT antenna Reply with quote
Chris,
Perfect explanation using facts and data.
The system of FSDOs and DARS provides opportunities for "I thinks" to become unfounded and undocumented requirements. On my FSDO RV-10 inspection, he had some understanding of multiple wavelength antenna radiation patterns so my empennage mounted ELT antenna was not an issue. He did however have a hard requirement for a TSO certified wet compass. I pointed out to him the real requirement being "a magnetic heading reference" and since I have two ADHRS units I more than met the requirement. I knew this up front so I elected to roll on it. I mounted the TSO wet compass from Vans - and got the sign off.
The upside is this is a real nice wet compass - that I carefully calibrated, connected it to the dimmer circuit, and will never use.
Carl
On Aug 29, 2012, at 10:15 AM, "Chris Hukill" <cjhukill(at)cox.net (cjhukill(at)cox.net)> wrote:
Chris Hukill
://www.matronics.com/Navigator?RV10-List
cs.com
matronics.com/contribution
Tim Olson
PostPosted: Wed Aug 29, 2012 6:58 am    Post subject: ELT Antenna Reply with quote
Not that I'd call this a "best" place by any means, but
I put mine right above the elevator trim stuff, between
the 2 trim cables, on top of that upper deck, under
the vertical stab, with the antenna facing back next to it
under the VS. For me, it was good for W&B, and it
also makes it easy to replace the batteries (even though
it's a 5 year thing now) because just pulling that
fairing gives full access. Should be a beefy place
on the structure and if I go in, the tail should go
in last. Smile
it.
Kelly
> Tim
PostPosted: Wed Aug 29, 2012 7:31 am    Post subject: ELT Antenna Reply with quote
That's exactly where and how I have mounted them myself. Just like having the data plate on the tail, that's the part that will probably survive a crash best. I also fully agree with the polarity arguments. If I can land with the wheels down and the VS up, then the ELT won't help much.
Jesse Saint
Saint Aviation, Inc.
C: 352-427-0285
F: 815-377-3694
Goto page 1, 2  Next
Page 1 of 2
