IO360B / O360A Fuel pump gasket
recapen(at)earthlink.net
PostPosted: Sun Sep 09, 2012 4:35 am    Post subject: IO360B / O360A Fuel pump gasket Reply with quote
I am adding a fuel pump cooling shroud to help prevent vapor lock.
The fuel pump gasket tore around the bolt-hole as I took the pump off to add the cooling shroud.
Anyone know where to get a replacement gasket?
It looks like an old chevy fuel pump gasket – in fact the pump has AC on the top…..
Thanks in advance,
Ralph
RV6A N822AR – reassembling after inspections brought on by the tornado induced prop strike by my hangar door.
Gary.A.Sobek
PostPosted: Sun Sep 09, 2012 4:57 am    Post subject: IO360B / O360A Fuel pump gasket Reply with quote
www.aeroinstock.com is where I purchased mine at.
GarySent from my iPhone
On Sep 9, 2012, at 5:39 AM, "Ralph E. Capen" <recapen(at)earthlink.net (recapen(at)earthlink.net)> wrote:
[quote] <![endif]--> <![endif]-->
Thanks in advance,
Ralph
Kellym
PostPosted: Sun Sep 09, 2012 5:10 am    Post subject: IO360B / O360A Fuel pump gasket Reply with quote
Any place that carries standard Lycoming parts and gaskets will have it.
On 9/9/2012 5:57 AM, RV6 Flyer wrote:
www.aeroinstock.com <http://www.aeroinstock.com> is where I purchased
mine at.
Gary
> on the top…..
> Thanks in advance,
> Ralph
���~��,�g���M4�G�q���z����.�'�
8ER��&j)E���K��j��',.+-歺
��5�â�«h����,x zf�ȸ���b�+bz�.r�.+-Rҹ��*m���!��y�܄:0�Zw�����ǂ��E��h��y�ݚ�!��!������i��0�f����r�(��Z�(���T���m����
���'���o�j�j�+ER���M� $�NEC&z
�j�(�ק��l��ڊV����j�^Y���������ߢ���f����r�(�m��ߢ���f����r�(����*'����ب�g�J+^8�L���+ʋ���ޮ����i��1�m�������)j�|���� &j��',r��r��&�*'��i��0�f����r�(��(���n�b���ߢ{���n�r�fl===
Kelly McMullen
KCHD
krhooper(at)gmail.com
PostPosted: Sun Sep 09, 2012 5:26 am    Post subject: IO360B / O360A Fuel pump gasket Reply with quote
If all else fails or you want to finish today, get some gasket material and cut out your own.
Randy Hooper
Sent from my iPad
On Sep 9, 2012, at 7:38 AM, "Ralph E. Capen" <recapen(at)earthlink.net (recapen(at)earthlink.net)> wrote:
Thanks in advance,
Ralph
/www.matronics.com/Navigator?RV-List
cs.com
matronics.com/contribution
