bryanmmartin
Posted: Sun Jun 04, 2006 2:17 pm Post subject: oil seal part number |
Does anybody know the part number for the oil seal for the lower
redrive bearing? I got my airplane back in the air today but it's
leaking oil from the seal.
Bryan Martin
do not archive.
| | - The Matronics Stratus-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Stratus-List |
_________________ --
Bryan Martin
do not archive. |
Posted: Sun Jun 04, 2006 4:04 pm Post subject: oil seal part number |
Bryan,
The seal you need is the National 415021. I will forward an info sheet
on these seals.
Larry McFarland - 601HDS at www.macmachine.com
Bryan Martin wrote:
<bryanmmartin(at)comcast.net>
bryanmmartin
Posted: Sun Jun 04, 2006 5:24 pm Post subject: oil seal part number |
Thanks, I'll look for one.
On Jun 4, 2006, at 8:02 PM, LarryMcFarland wrote:
Bryan,
sheet on these seals.
Bryan Martin
do not archive.
Bryan Martin
do not archive. |
Billvt
Posted: Mon Jun 05, 2006 4:20 pm Post subject: oil seal part number |
Bryan,
When I replaced my seal, I found that the large aluminum spacer that goes between the flywheel and crankshaft had a groove worn into it from the rubber seal. This spacer should be steel to prevent this but it is not. So not only does the seal wear, but the surface the seal rides on also wears.
When inserting the new seal, I did not press it in all the way but rather left is out about a 16th of an inch or so to let the new seal have an undamaged surface to ride on. There was plenty of room behind the flywheel to allow the seal to be sticking out this amount.
My next problem will be when the seal starts leaking again, I will have a second groove in the spacer and won't be able to pick a new spot.
There are a couple of things I could do. One is to have a steel spacer made. Probably expensive and would add a bit of weight. The second is to place a stainless sleeve over the spacer. I was at my local bearing store one day and saw a brochure (which I can't find now) for a very thin stainless sleeve that would fit over the spacer to repair the damage. The sleeves come in all different sizes and are very thin so as not to change the diameter very much. They are made just for repairing worn shafts and I think would work on the Stratus spacer. I will try and find the brochure so I can pass the company name along to you guys.
If anyone would like, I have photos showing the spacer damage that I had and I would be glad to send them. Just send me a note off the zenith list. I can also send a write up I did on how I replaced the seal.
Bill (N812BM - 601HDS - Tri - Stratus (RAM Heads) - Vermont - 455.7 flight hrs. - 619 landings
web site -> http://homepages.together.net/~billvt/
