582 cutting out at WOT
ktnc420
PostPosted: Fri Sep 14, 2012 4:22 pm    Post subject: 582 cutting out at WOT Reply with quote
My 582 gray runs normal up to about 5700 rpms. When I try to go to full throttle, it starts cutting out.
I've replaced all fuel lines and filters and rebuilt the fuel pump. The problem occurs with the elec. pump on too.
The carb floats seem to working properly and needles look good.
Any ideas on what to check next?
This started happening after somewhat of a hard pull-up to 70 degs. or so, then leveling off.
The motor is in pusher config. in a Kolb Mark III.
I'm stumped. SOS
cristalclear13
PostPosted: Tue Sep 18, 2012 11:47 am    Post subject: Re: 582 cutting out at WOT Reply with quote
I'm stumped. SOS
Ktnc420, How do your spark plugs look?
Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009
ktnc420
PostPosted: Wed Sep 19, 2012 3:48 am    Post subject: Re: 582 cutting out at WOT Reply with quote
Hi Cristal
The plugs looked good but I replaced them anyway. Compression is also good in both cylinders.
You sold your Kolb?!
cristalclear13
PostPosted: Wed Sep 19, 2012 7:36 am    Post subject: Re: 582 cutting out at WOT Reply with quote
ktnc420 wrote:
Hi Cristal
Yes, it was a sad day, but I didn't have the money or time right now to put into her. She got a new owner who was happy to start sprucing her up. My next Kolb will probably be a Mark III.
A couple other things to check on your engine is the choke piston (one time I had a deteriorated seal that was giving me problems) and you could also check the needle clip in your carb and the o-ring.
http://www.ultralightnews.ca/bing/needleclipupdate.htm
http://www.ultralightnews.ca/bing/bingcarbdisassemblytip.html
Cristal Waters
cristalclear13
PostPosted: Wed Oct 03, 2012 12:37 pm    Post subject: Re: 582 cutting out at WOT Reply with quote
I'm stumped. SOS
ktnc420, Did you ever find your problem? I found my repair book which takes you through several things to check. I will type them up here if you still need help.
Cristal Waters
ktnc420
PostPosted: Thu Oct 04, 2012 5:04 am    Post subject: Re: 582 cutting out at WOT Reply with quote
The problem went away after cleaning the carbs. I did see some small orange colored goo balls in the bowls after removing the floats. That must have been it.
Thanks!
