		bob.kaufmann(at)gmail.com Guest
				 Posted: Tue Sep 11, 2012 11:26 am    Post subject: Vinyl |
				Has anyone used any vinyl artwork and how well does it work?
 Bob K
 On Sep 11, 2012, at 9:10 AM, "duawil" <aaa(at)pacifier.com> wrote:
		rene(at)felker.com Guest
				 Posted: Tue Sep 11, 2012 11:36 am    Post subject: Vinyl |
				I had some done.
 Decals for doors.....
 Aircraft Name on Tail (Curious George)
 RV-10 on tail
 4.5 years and are holding up great.
 The graphics shop also did the stencils for the 12" aircraft numbers
 Rene' Felker
 N423CF
 801-721-6080
				 Posted: Tue Sep 11, 2012 2:46 pm    Post subject: Vinyl |
				I was considering some custom vinyl graphics for my 8A. These people were recommended to me based on their prior work. It's especially inexpensive if you get multiple items gang printed. Also make sure you order the premium vinyl with lamination as it reportedly holds up better when exposed to UV and the elements.
 (includes some notes from my records)
 Stickers: http://ocsigns.com/decal_calculator.php
 Prints to "match" Pantone or PMS colors.
 Suggest Premium Vinyl Adhesive Decals with Lamination.
 Order Vinyl Letters at the same time to match Sheen & Color
 Gang print Stars & Bars etc...
 Robin
		TimRVator(at)comcast.net Guest
				 Posted: Sun Sep 16, 2012 10:27 am    Post subject: Vinyl |
				I bought a relatively inexpensive vinyl cutting machine from
 UScutter.com, and used it to cut the vinyl for N number, stripes, door
 label, fuel label, "Experimental" label, etc. on my RV-10.  I used
 12-year vinyl (Oracal).  I designed/laid out the graphics with the free
 Inkscape program.
 Here's a photo somebody took of me landing at Airventure '11:
 http://www.airport-data.com/aircraft/photo/649281.html
 Results were generally good.  Observations/lessons learned:
 - Using vinyl allowed me to paint the airplane all white (in the
 basement, before flight) without having to mask for additional colors,
 designs, letters, etc.
 - Vinyl works fine on surfaces parallel to air flow
 - When dings happen, vinyl is pretty easy to patch
 - Prop-driven rain is hard on the portion of the vinyl that faces the
 airflow (top of vertical stabilizer).  Especially hard hit is the seam
 where the fiberglass VS tip intersects the aluminum top of VS.  If I had
 it to do over again I wouldn't wrap vinyl around the front of the VS
 - It's more fun to fly than to apply graphics -- I never did finish the
 vinyl graphics on the copilot side, nor a planned swoosh on the pilot side.
 Tim Lewis -- HEF (Manassas, VA)
 RV-6A N47TD -- 1104 hrs - sold
 RV-10 N31TD -- 300 hrs
 Bob Kaufmann said the following on 9/11/2012 3:25 PM:
  Bob K
 > Thanks everyone for all the suggestions/info.
 > I am going ahead with the install of what I got from Flyboyaccessories.com after discussing it with Abby.
 > Building RV10.
 > http://forums.matronics.com/viewtopic.php?p=382878#382878
				 Posted: Sun Sep 16, 2012 11:01 am    Post subject: Vinyl |
				Thanks questions answered.
 On Sep 16, 2012, at 12:26 PM, Tim Lewis <TimRVator(at)comcast.net> wrote:
  I bought a relatively inexpensive vinyl cutting machine from UScutter.com, and used it to cut the vinyl for N number, stripes, door label, fuel label, "Experimental" label, etc. on my RV-10.  I used 12-year vinyl (Oracal).  I designed/laid out the graphics with the free Inkscape program.
  Here's a photo somebody took of me landing at Airventure '11: http://www.airport-data.com/aircraft/photo/649281.html
  - Using vinyl allowed me to paint the airplane all white (in the basement, before flight) without having to mask for additional colors, designs, letters, etc.
  - Prop-driven rain is hard on the portion of the vinyl that faces the airflow (top of vertical stabilizer).  Especially hard hit is the seam where the fiberglass VS tip intersects the aluminum top of VS.  If I had it to do over again I wouldn't wrap vinyl around the front of the VS
  - It's more fun to fly than to apply graphics -- I never did finish the vinyl graphics on the copilot side, nor a planned swoosh on the pilot side.
 > Bob K
 > Sent from my iPad
 >> Building RV10.
