Nose gear bungee resting position ?
mbima(at)hydro.mb.ca
PostPosted: Thu Aug 23, 2012 4:35 am    Post subject: Nose gear bungee resting position ? Reply with quote
Hello,
I just installed a new bungee and the nose gear is about 1" from the stop when on the ground (at the stop when the nose is lifted off the ground).
Is this normal? Or should the bungee hold the nose gear against the stop all the time except for rolling on bumpy ground or a landing.
Martin
dougsnash
PostPosted: Thu Aug 23, 2012 4:45 am    Post subject: Nose gear bungee resting position ? Reply with quote
What you have is normal. Being against the stop makes the steering a little stiff.
Doug M
Sent from my iPad
On 2012-08-23, at 7:32 AM, "Bima, Martin" <mbima(at)hydro.mb.ca> wrote:
Hello,
Martin
ronlee
PostPosted: Mon Aug 27, 2012 8:04 am    Post subject: Re: Nose gear bungee resting position ? Reply with quote
That is where mine rests too.
Ron Lee
Tucson, Arizona
