ceengland7(at)gmail.com Guest
Posted: Thu Sep 20, 2012 4:51 pm Post subject: Why did this AMP crimp on connection get singed and fail? |
On 09/20/2012 03:52 PM, Bill Watson wrote:
<Mauledriver(at)nc.rr.com>
My strobes suddenly stopped flashing.
Stumbling through some basic problem determination, I checked that
power was getting to Avi-Pak 60W Strobe power supply. Per the Avi-Pak
documentation I unplugged all 3 of the strobe connectors and plugged
one in at a time to check for a defective strobe unit.
Everything check out okay except that sometimes I was getting 12+
volts to the power supply and other times I seemed to be getting about
8 volts. Thinking that I may have had a loose connection somewhere, I
checked the circuit's voltage while wriggling various connection
points. The voltage sometimes change from 12+ to 8 volts but I
couldn't correlate the change with any of my wriggling. In addition,
I would occasionally get a flash or two from the strobes. But again,
no correlation with my wriggling.
I replaced the Avi-Pak unit with a general purpose, almost plug
compatible unit from the manufacturer, Nova. It failed to work as
well. However, it has some diagnostic lights on it which indicated
that the unit was getting less than 10 volts. At times, the unit
would flash the strobes for a few seconds, then go back into
under-voltage mode.
I finally found the culprit while examining my fuse panel. The AMP
slide on connector for the strobe circuit was singed or burned a bit.
I replaced it and now everything works fine.
Here are some pics of the connector after I had slit the insulation:
https://dl.dropbox.com/u/60509998/Burned%20crimp%201.JPG
https://dl.dropbox.com/u/60509998/Burned%20crimp%202.JPG
https://dl.dropbox.com/u/60509998/Burned%20crimp%203.JPG
Everything about the crimp appears fine to me. I used a band saw to
cut half way thru it but it looks solid.
Any thoughts about what would cause the singeing and the variable
voltage? I'd like to understand what went wrong with this crimp.
Bill "owner of 2 working strobe power supplies" Watson
It's hard to tell from a photo, but the 3rd pic (with the sawed cut into
the crimp) looks like there is orange insulation inside the crimp at the
cut. Is that the case?
Charlie
mauledriver(at)nc.rr.com Guest
Posted: Thu Sep 20, 2012 8:29 pm Post subject: Why did this AMP crimp on connection get singed and fail? |
Yes, I've been looking closely at the cut too. I can't see any thing that looks like insulation imbedded in the crimp. It looks like 100% metal.
But, it looks like the center of the crimp is brass (where it should be copper wire). And the perimeter of the splice looks like copper (which is consistent with the tin plated copper construction of the AMP PIDG Fast-on connector.
Anyway, I was examining the cut connector very closely to see if it had been in adequately stripped. I can't clearly see any sign of that but it is a possibility.
Bill 'baffled' Watson
Sent from my iPad
On Sep 20, 2012, at 8:50 PM, Charlie England <ceengland7(at)gmail.com> wrote:
> Stumbling through some basic problem determination, I checked that power was getting to Avi-Pak 60W Strobe power supply. Per the Avi-Pak documentation I unplugged all 3 of the strobe connectors and plugged one in at a time to check for a defective strobe unit.
> Everything check out okay except that sometimes I was getting 12+ volts to the power supply and other times I seemed to be getting about 8 volts. Thinking that I may have had a loose connection somewhere, I checked the circuit's voltage while wriggling various connection points. The voltage sometimes change from 12+ to 8 volts but I couldn't correlate the change with any of my wriggling. In addition, I would occasionally get a flash or two from the strobes. But again, no correlation with my wriggling.
> I replaced the Avi-Pak unit with a general purpose, almost plug compatible unit from the manufacturer, Nova. It failed to work as well. However, it has some diagnostic lights on it which indicated that the unit was getting less than 10 volts. At times, the unit would flash the strobes for a few seconds, then go back into under-voltage mode.
> I finally found the culprit while examining my fuse panel. The AMP slide on connector for the strobe circuit was singed or burned a bit. I replaced it and now everything works fine.
> Everything about the crimp appears fine to me. I used a band saw to cut half way thru it but it looks solid.
> Any thoughts about what would cause the singeing and the variable voltage? I'd like to understand what went wrong with this crimp.
> Thanks,
It's hard to tell from a photo, but the 3rd pic (with the sawed cut into the crimp) looks like there is orange insulation inside the crimp at the cut. Is that the case?
Charlie
raymondj(at)frontiernet.n Guest
Posted: Sat Sep 22, 2012 1:09 pm Post subject: Why did this AMP crimp on connection get singed and fail? |
Bill,
Search "switches with faston tabs" in the AeroElectric archives. They
discuss the discoloration of the faston insulation as the result of
switch failure. Time frame of sept 08.
Raymond Julian
Kettle River, MN.
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine
under-voltage mode.
