		mau11(at)free.fr Guest
				 Posted: Fri Oct 05, 2012 3:22 am    Post subject: Power Flarm antennas |
				Hi all,
  Does anyone have experience with powerFlarm?
  What is the best antennas position?
  I use one last week and I receive signal only when two antennas are in  vertical position.
  When the powerflarm body is positioned on top of the panel below  windscreen, with antennas in 45° position no signal.
  Many thanks
  Michel AUVRAY
  F-PFGT - 145
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Fri Oct 05, 2012 3:07 pm    Post subject: Power Flarm antennas |
				I have a full wave loop antenna, it fits neatly behind the baggage bay bulkhead. Inside the garage, doors closed
 With the airport 29.6km (according to google maps) off my starboard wing, the ATIS is so strong MAX squelch still
 Doesn’t cut the transmission off. I am told that the reception should be degraded to port and starboard because of the loop giving
 Best reception/ trans through the hole in the middle (ie fore/aft), keep in mind that comm. Signals are vertically polarized so if your antenna
 Is laying flat on top of the panel the reception might be effected.
 Good luck
 craig
 From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of mau11
  Sent: Friday, October 05, 2012 9:22 PM
  Subject: Power Flarm antennas
 Hi all,
 Many thanks
 Michel AUVRAY
 F-PFGT - 145
    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Europa-List  | 	  0123456789
  Checked by AVG - www.avg.com
  10/04/12
		kpeng
				 Posted: Sat Oct 06, 2012 1:16 am    Post subject: Power Flarm antennas |
				Hi Michel,
                  I have Powerflarm Pcas mobile mounted on a RAM mount suction cup on the windscreen to the left near to the doorframe. The anntena can then stand vertical and work fine and is easy to see and use with no restriction on my view. Powerflarm give's me firm contacts with ADS-B and Flarm equipped(plus gliders) aircraft with 360 deg position and altitude . Mode C & S are given range and relative altitude to you.When powerflarm is linked to my Trig31 mode s transponder it will also  give me ADS-B out.
                              Kevin.
 On 6 Oct 2012, at 00:06, "craig" <craigb(at)onthenet.com.au (craigb(at)onthenet.com.au)> wrote:
 [quote]       v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);}  <![endif]-->      p.MsoNormal 	{margin-left:7.5pt;}     <![endif]-->       <![endif]-->
 Good luck
 craig
 From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of mau11
 Hi all,
 Many thanks
 Michel AUVRAY
 F-PFGT - 145
   0123456789
  10/04/12
