Posted: Tue Oct 16, 2012 9:07 am Post subject: Thermocouple testing |
At 10:13 AM 10/16/2012, you wrote:
| Quote: | Bob,
I ordered 3 of the devices. When comparing them at room temp they varied over a range of about 3 deg. Any info on what screw does what, or shall I just start twisting screws and see what happens ? I'm not as concerned with accuracy as I am with consistency across them for measuring temp differences. |
I've not explored the functionality of the two pots.
One will be offset (probably calibrated at the lower
temperature) and the other is scale factor (higher
calibration point).
You'll need a water-ice bath of distilled or RO
water and crushed ice. Also a boiling cup of
water . . .
Put dip into alternate baths, wait for stable
reading and then adjust pot for either 0 or
100 as appropriate. Each excursion/calibration
cycle between the two baths should display
smaller errors. If the errors are growing,
try reversing which pot is twisted for what
temperature.
Let us know what you discover!
Bob . . . [quote][b]
