Engine Mount Slump
Greg McFarlane
PostPosted: Thu Oct 25, 2012 2:11 am    Post subject: Engine Mount Slump Reply with quote
Rolling Eyes Just fitting top cowl, what is the experience of flying RV10s regarding the amount the engine/mounts drop/settle after say 100 hours, typically the smaller 0320 & 0360 in sixes etc drop about quarter inch at the back of the spinner is this about the same for the 10 with the 0540. Cheers from Western Australia
dave.saylor.aircrafters(a
PostPosted: Thu Oct 25, 2012 2:57 am    Post subject: Engine Mount Slump Reply with quote
We set the top cowl 1/8" to 3/16" below the upper edge of the spinner.  It drops down just right.  Don't worry about the gap changing between the spinner and prop.  If you get it right from the start it doesn't change.
Dave Saylor
831-750-0284 CL
On Thu, Oct 25, 2012 at 3:11 AM, Greg McFarlane <grbcmcfarlane(at)gmail.com (grbcmcfarlane(at)gmail.com)> wrote:
[quote] --> RV10-List message posted by: "Greg McFarlane" <grbcmcfarlane(at)gmail.com (grbcmcfarlane(at)gmail.com)>
[Rolling Eyes] Just fitting top cowl, what is the experience of flying RV10s regarding the amount the engine/mounts drop/settle after say 100 hours, typically the smaller 0320 & 0360 in sixes etc drop about quarter inch at the back of the spinner is this about the same for the 10 with the 0540. Cheers from Western Australia
http://forums.matronics.com/viewtopic.php?p=385971#385971
" target="_blank">http://www.matronics.com/Navigator?RV10-List
MS -
e -
         -Matt Dralle, List Admin.
carl.froehlich(at)verizon
PostPosted: Thu Oct 25, 2012 4:29 am    Post subject: Engine Mount Slump Reply with quote
On my 8A I biased the cowl ¼� down on the spinner (as in ¼� from the spinner being exactly in the center).  10 years and 700 hours later it is still ¼� down – so no engine slump.
On the 10 I did the same but with the James Cowl that translated to the top of the spinner being flush the top of the cowl, and the bottom of the spinner being ¼� above “flush� to the bottom of the cowl.  58 hours so far and the engine has not moved.
I’ve seen a few long time flying RVs with the spinner proud above the top of the cowl.  You may not want to bias the cowl beyond the top of the spinner being flush with the top of the cowl.
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor
Sent: Thursday, October 25, 2012 6:57 AM
Subject: Re: Engine Mount Slump
Dave Saylor
831-750-0284 CL
MS -
e -
rleffler
PostPosted: Thu Oct 25, 2012 5:28 am    Post subject: Engine Mount Slump Reply with quote
I set my cowl the same as Dave's a year ago. Mine hasn't dropped yet. Although, I'm not flying yet.
On Oct 25, 2012, at 6:56 AM, Dave Saylor <dave.saylor.aircrafters(at)gmail.com (dave.saylor.aircrafters(at)gmail.com)> wrote:
Dave Saylor
831-750-0284 CL
MS -
e -
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
philperry9
PostPosted: Thu Oct 25, 2012 5:34 am    Post subject: Engine Mount Slump Reply with quote
I'm interested in knowing how long the engine hung on the mount before the cowling was fitted; then what the drop results were.
Mine has been hanging for nearly a year and I can't imagine getting it to drop too much more - even when it starts operating.
Phil
On Thu, Oct 25, 2012 at 8:27 AM, Bob Leffler <rv(at)thelefflers.com (rv(at)thelefflers.com)> wrote:
[quote] I set my cowl the same as Dave's a year ago.  Mine hasn't dropped yet.  Although, I'm not flying yet.
Dave Saylor
[url=tel:831-750-0284]831-750-0284[/url] CL
MS -
e -
Tim Olson
PostPosted: Thu Oct 25, 2012 5:49 am    Post subject: Engine Mount Slump Reply with quote
This isn't a measurement exactly, but I'll tell you I planned
for mine to drop based what other non-RV-10 builders were saying
at the time, since I was one of the earlier completions.
I found that it didn't drop for my RV-10 nearly as much as I
expected it to based on what they said. So I'd go with your
first reply and maybe do a max of 1/8" or 3/16" if you really
want to push it. Chances are you'll end up about right maybe
with 1/8" but any more and it may be high forever.
Phil
jfrjr(at)roadrunner.com
PostPosted: Thu Oct 25, 2012 5:59 am    Post subject: Engine Mount Slump Reply with quote
At initial build I fitted the cowling to match the spinner and the engine had only been hanging for about a month. Then after two years and 250 hours of flying the drop was about 1/4 inch--fairly easy to correct by placing washers (1 thin and 1 thick) on the bottom motor mounts. I had to unbolt twice to get the proper washer thickness in order to have a perfect height. It may be possible to mathmatically calculate the washer thickness but that would be way above my pay grade. Jay Rowe
On Oct 25, 2012, at 6:33 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
[quote]I'm interested in knowing how long the engine hung on the mount before the cowling was fitted; then what the drop results were.
Phil
Dave Saylor
MS -
e -
cs.com
rleffler
PostPosted: Thu Oct 25, 2012 6:00 am    Post subject: Engine Mount Slump Reply with quote
Hung the engine 2/5/11. Cowl was fitted four weeks later. So it's been about 20 months with no drop. So when you see the hub sitting 1/8" proud at OSH, you'll know why.
On Oct 25, 2012, at 9:33 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
Phil
Dave Saylor
MS -
e -
Bob Leffler
N410BL - Phase I
philperry9
PostPosted: Thu Oct 25, 2012 6:07 am    Post subject: Engine Mount Slump Reply with quote
As long as we see it sitting proud at OSH.
On Thu, Oct 25, 2012 at 9:00 AM, Bob Leffler <rv(at)thelefflers.com (rv(at)thelefflers.com)> wrote:
[quote]Hung the engine 2/5/11.  Cowl was fitted four weeks later. So it's been about 20 months with no drop.  So when you see the hub sitting 1/8" proud at OSH, you'll know why.
Phil
ScooterF15
PostPosted: Thu Oct 25, 2012 7:48 am    Post subject: Engine Mount Slump Reply with quote
I set mine up 3/8 inch. At 200 hours spinner is level with the cowl.
-Jim
N312JE
Sent from my mobile device
ScooterF15
PostPosted: Thu Oct 25, 2012 7:49 am    Post subject: Engine Mount Slump Reply with quote
Correction 3/16 inch.
-Jim
-Jim
N312JE
> RV10s
rv10rob(at)gmail.com
PostPosted: Thu Oct 25, 2012 1:28 pm    Post subject: Engine Mount Slump Reply with quote
Ours didn't drop any noticeable amount.  We used the Lord mounts (the others weren't available), which I've heard results in less dropping, but you'll find plenty of people that have seen a drop with the Lords, so seems difficult to preduct.
-Rob
On Thu, Oct 25, 2012 at 8:48 AM, James McGrew <jsmcgrew(at)alum.mit.edu (jsmcgrew(at)alum.mit.edu)> wrote:
--> RV10-List message posted by: James McGrew <jsmcgrew(at)alum.mit.edu (jsmcgrew(at)alum.mit.edu)>
-Jim
On 10/25/12, James McGrew <jsmcgrew(at)alum.mit.edu (jsmcgrew(at)alum.mit.edu)> wrote:
> -Jim
> N312JE
> On 10/25/12, Greg McFarlane <grbcmcfarlane(at)gmail.com (grbcmcfarlane(at)gmail.com)> wrote:
>> RV10s
le, List Admin.
Rob Kochman
RV-10 Flying since March 2011
Woodinville, WA
http://kochman.net/N819K
Tim Olson
PostPosted: Thu Oct 25, 2012 1:44 pm    Post subject: Engine Mount Slump Reply with quote
I'm thinking that the reason some have a little more drop
than others, may be that some people hang their engine and
have it sitting on there for a while during the build and
some get through the cowl fit process quicker. They must
move down pretty quickly initially, but not move very much
over time after the initial "set".
-Rob
Greg McFarlane
PostPosted: Fri Oct 26, 2012 3:58 am    Post subject: Re: Engine Mount Slump Reply with quote
Thanks for all the replies, will go with Dave's suggestion of 1/8 to 3/16 of an inch, engine has only been on a month so I expect until first start and then first 100 or so hours I will see that expected drop. Apparently static sitting has very little impact on the mounts, which in my case are Lords, it's the flying loads that have the effect, heat and torque loads etc. My local AP (approved person) has said to me that it's much better visually to have the spinner sitting high in relation to the top cowl than the other way around, but as has been said even after some time flying, if you need to "pick up-even out " the set of the spinner to cowls the mounts themselves can be packed with spacers. It's way above my pay scale as well to work any formula for that one, it just goes to show its an art not a science. Cheers again from Western Australia
rv10flyer
PostPosted: Fri Oct 26, 2012 7:37 am    Post subject: Re: Engine Mount Slump Reply with quote
Van's instructions say after all of the fitting to install the smaller diameter pins in the top rear hinges. That just gave me another .025" gap at the top rear and lowered the front another 1/16". I ended up with top of cowl 3/16" lower. I had engine hanging very little before fitting cowl. The relative position has not changed, but the cowl hinge eyelets do wear hence the black streaks found after flying occasionally. So I think my cowl has dropped slightly in 88 hours and engine has sagged the same. If everyones stock cowl fits like mine the bottom sticks out below. If I was doing it over, I would keep top rear cowl gap tight with no clearance during fitting. I also would provide 1/4" clearance between spinner back plate and fwd cowl to make removal easier. 1/8" is just too close. I would also cut slot for nose gear leg fairing 2" deeper with removaable piece/nutplates.
Wayne G.
PostPosted: Fri Oct 26, 2012 2:54 pm    Post subject: Engine Mount Slump Reply with quote
+1 on the spinner/cowl clearance and the larger slot for the gear leg.  I did the latter before paint, but the spinner/cowl gap would have been too much work to fix.
-Rob
On Fri, Oct 26, 2012 at 8:37 AM, rv10flyer <wayne.gillispie(at)gmail.com (wayne.gillispie(at)gmail.com)> wrote:
--> RV10-List message posted by: "rv10flyer" <wayne.gillispie(at)gmail.com (wayne.gillispie(at)gmail.com)>
Wayne Gillispie
http://forums.matronics.com/viewtopic.php?p=386043#386043
le, List Admin.
Rob Kochman
Woodinville, WA
bill.peyton
PostPosted: Sat Oct 27, 2012 4:15 am    Post subject: Re: Engine Mount Slump Reply with quote
I guess I will add my two cents. When I fit the cowling my engine had only been hanging for 2 weeks. I used a 1/4" gap all around the spinner. I did not use a prop hub simulator, I used an old hub. I set the top of the cowl even with the spinners. After 6 months and 25 hours of flying, the spinner is now 1/8" lower than the top of the cowl. Most people won't notice it, but I do. I have acquired spacers that I am going to use at the first annual to raise the engine back up to even. Some of the slumping occurred prior to flying.
I also added around 2 inches to the opening for the gear leg.
Something that will ease the cowl removal and install process is to split the inlet baffle for the FAB. I installed only the lower and side baffles on the "cowl side" of the inlet, and the upper baffle on the FAB box inlet. That way when it is removed the cowl simply falls away from the baffle on the FAB box. It makes is much easier to remove the lower cowl.
Bill
WA0SYV
Aviation Partners, LLC
