barryjedwards(at)lineone. Guest
Posted: Mon Oct 22, 2012 11:42 am Post subject: Propeller Choices |
Hi Brian,
I’d be interested to hear what Arplast have to say about maintenance of an ‘old’ PV50. Mine is getting on for 15 years old and must have around 600 hours on it now. No problems at all with it since all the early problems were ironed out (mine was a very early model) but it would be nice to hear what they have to say. The UK distributer closed down a few years ago so there is no direct support (that I know of) in the UK.
Barry
G-XPXP Taildragger, 1040 hrs
Sent: Monday, October 22, 2012 7:56 PM
To: pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Subject: Re: Propellor Choices
--> Pulsar-List message posted by: Brian Anderson <briana(at)xtra.co.nz>
Hi Bill,
I also have the PV50. It's done about 460 hours now [12 years old] and I have been wondering about the life. I remember reading in some of the early Arplast documentation [ - - very limited] that the nominal life was 500 hours. It's a great prop, and I agree about the performance improvements being able to adjust the pitch in flight.
Some time ago I also had a motor failure. The motor just wouldn't start and move in one direction. I talked to Arplast and they sold me an "improved" motor. No troubles since. Each annual I open the prop hub, clean out any hardened grease and re-grease. In fact I did that yesterday, and checked the operation. All is OK. The new motor was supplied with the lead screw and bearing. The old bearing was a bit rough and lumpy too. In the meantime I had purchased a replacement bearing locally anyhow. It is a standard [metric] size and was easy to find.
I can't imagine the lead screw stripping. It is fairly substantial.
I was about to write an email to Arplast to ask about the life, and any particular maintenance that might be necessary. If I need to think about a new prop I would still think seriously about the Arplast again.
Brian
On 23/10/2012, at 1:50 AM, Bill Landucci <bill.landucci(at)tds.net> wrote:
| Quote: | --> Pulsar-List message posted by: Bill Landucci <bill.landucci(at)tds.net>
Hello All,
I've been flying N168TM (Pulsar III - 912ULS) for almost ten years with the Arplast PV50. The plane is ready for a new prop. What are folks using these days with Pulsars? I must admit that the simplicity of a fixed pitch prop is appealing, but I'm afraid I may have gotten used to the in-flight adjustable's ability to optimize for climb and cruise.
During the last flight the pitch motor failed to adjust the prop pitch. This time the electric motor is spinning freely so I suspect a stripped lead screw. In past years I've had that happen one other time, plus two failed electric pitch motors. Fortuntately the failure mode is always the same - pitch is stuck where you last had it. So as long as pitch range is limited to safe flight you're okay, but it does make the cross country longer when top speed is 110mph due to engine rpm.
If anyone has old Arplast parts I'd consider buying. But something completely different might be the best solution at this point.
Bill
p; Navigator Photoshare, and p; the Web ========================<; generous bsp;
briana(at)xtra.co.nz Guest
Posted: Tue Oct 23, 2012 12:54 pm Post subject: Propeller Choices |
Hi Barry,
I received a brief reply overnight. Arplast now say that there is no limited life.
Laetitia, whom I have spoken to briefly in the past, provided some additional maintenance information. Unfortunately it is a .jpg copy and in French, so it is not easy to translate automatically. As far as I can determine there is nothing particularly new about the information, so provided we continue to grease the bearings and lead screw it should all be OK.
I will send the .jpg information separately. Maybe your French language skills are better than mine, so if you see anything useful perhaps you can advise.
Brian.
On 23/10/2012, at 8:41 AM, Barry J Edwards <barryjedwards(at)lineone.net (barryjedwards(at)lineone.net)> wrote:
[quote] Hi Brian,
Barry
--> Pulsar-List message posted by: Brian Anderson <briana(at)xtra.co.nz (briana(at)xtra.co.nz)>
Hi Bill,
Brian
On 23/10/2012, at 1:50 AM, Bill Landucci <bill.landucci(at)tds.net (bill.landucci(at)tds.net)> wrote:
| Quote: | --> Pulsar-List message posted by: Bill Landucci <bill.landucci(at)tds.net (bill.landucci(at)tds.net)>
Hello All,
Bill
href="http://www.matronics.com/Navigator?Pulsar-List">http://www.matronics.com/Navigator?Pulsar-List
freedom4life(at)xtra.co.n Guest
Posted: Thu Oct 25, 2012 9:01 pm Post subject: Propeller Choices |
Barry,because of the large speed envelope of the Pulsar any fixed pitch prop is going to be a very limited in its performance. I tried several two and three blade ground adjustable props before fitting the Airmaster CS propeller system. Three blades gave very good take of performance but was so restrictive in top end speed (like driving your car in low gear) and the two blades gave very poor take off performance with reasonable top end speed. (Try taking off in overdrive in your car!) Because I always fly off grass which is often wet and long the end fence was always coming up very quickly before getting airborne! The Pulsar benefits so much from the three bladed constant speed prop as it fines itself up to give maximum HP from the engine with resulting rapid acceleration. At the other end of the spectrum it allows a high top speed with normal engine speeds at 5,000 rpm. My 80HP XP will do 144 knots straight and level with the Airmaster. It wouldn’t get close to that with original two bladed GSC prop. I did try several other propellers and despite the GSC only having three laminations and the blades warping and becoming different to each other, it was about the best compromised prop I tried. The Prince prop may well have been better but I never tried that.
I would say that the performance gained from the constant speed prop was better than 30%. Also slowing done in the pattern now is no trouble at all as the propeller does all the braking. You can approach much steeper for better visibility without going through your max flap speeds.
Cliff
Jim,
Thanks for the info. Is there an advantage to a three blade vs two blade?
Barry
Sent: Thursday, October 25, 2012 5:34:15 PM
Subject: RE: Propellor Choices
p { margin: 0px } Hi Barry,
I used the 3 blade Ivo medium before. The Airmaster is 3 blade as well and uses Warp blades. I like the inlaid nickel leading edges but here in Houston, have to keep a light coat of oil or grease on the nickel to avoid corrosion. I have seen around 5 mph improvement with the Airmaster. It is fully feathering but I haven't feathered it in flight. Something about killing a perfectly happy engine in flight bothers me.
A rotating switch is used to select the Takeoff (5,800 rpm), Climb (5,500) or Cruise (5,000) setting. There a Hold setting so you can select your rpm if you don't want to use one of the standard settings. There is also a Manual mode where you then use a toggle switch to increase or decrease pitch. This prop only consumes an amp or two vs. the Ivo which consumes more as it nears the stops, up to 10 amps or so. The Ivo achieves different pitch settings by warping the blades rather than rotating them in the hub.
Jim
[quote] From: owner-pulsar-list-server(at)matronics.com [mailto:owner-pulsar-list-server(at)matronics.com] On Behalf Of barrynorman(at)comcast.net
Sent: Thursday, October 25, 2012 3:56 PM
Subject: Re: Pulsar-List: Propellor Choices
Jim,
What prop did you have before? Did you get the 2 or three blade version? Was there in improvement in performance over the old one?
Barry
Sent: Thursday, October 25, 2012 12:17:53 PM
--> Pulsar-List message posted by: "pilot623" <pilot623(at)gmail.com>
I have to agree with Cliff. My Airmaster CS prop has been in use about 140
hours and as he says, it's simple to use in all phases of flight. I have not
had any maintenance issues. It's a bit heavier than most and certainly more
expensive but I love it and would buy it again. My previous experience was
with the Ivo in-flight adjustable. It worked fine but I did suffer a few
maintenance issues like replacing the internal drive motor twice. I'm no
aerodynamicist but the shape of the blades had me wondering if there were
some more efficiencies that could be had there. I've never operated my plane
with a fixed pitch prop.
Jim Fillman
N623JF
Series 2
Rotax 912S
-----Original Message-----
[mailto:owner-pulsar-list-server(at)matronics.com] On Behalf Of freedom4life
Sent: Monday, October 22, 2012 3:01 PM
--> Pulsar-List message posted by: "freedom4life"
--> <freedom4life(at)xtra.co.nz>
Hi Bill
I have been using a Constant Speed Airmaster Prop for the last 1500 hrs on
my Pulsar XP. In the circle of friends that I fly with more than 15 run this
same propeller. I have not had to do anything to it other than replace
brushes. It transformed my plane and I wouldn't replace it with anything
else. The controller is simple to use and brilliant. There are others in
the group running this prop so it would be good to hear their experience
too. I'm not an agent for these but I certainly endorse them.
http://www.airmasterpropellers.com/
Cliff
Hello All,
Bill
_p; &n====================
href="http://www.matronics.com/Navigator?Pulsar-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
arget=_blank>http://www.matronics.com/Navigator?Pulsar-List
