sbeaver(at)columbus.rr.co Guest
Posted: Mon May 28, 2012 11:27 am Post subject: 705-1000 manifold pressure regulator |
Looking for a 705-1000 regulating valve assembly. This unit fits between the throttle butterfly and the fuel injection pump and is used to regulate the pressures sensed by the fuel injection pump.
I would be grateful for any leads.
Steve
| - The Matronics Lom-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lom-List |
mark(at)aerocraftsman.com Guest
Posted: Mon May 28, 2012 12:37 pm Post subject: 705-1000 manifold pressure regulator |
Stephen,
Have you tried LOM directly? In my experience they have been very responsive and easy to deal with.
Mark Lightsey
M337C
Caudron C.460 replica
Sent from the iPad at AeroCraftsman
On May 28, 2012, at 12:26 PM, Stephen Beaver <sbeaver(at)columbus.rr.com (sbeaver(at)columbus.rr.com)> wrote:
[quote]Looking for a 705-1000 regulating valve assembly. This unit fits between the throttle butterfly and the fuel injection pump and is used to regulate the pressures sensed by the fuel injection pump.
Steve
cs.com
matronics.com/contribution
Posted: Mon May 28, 2012 12:46 pm Post subject: 705-1000 manifold pressure regulator |
Yes. I just emailed Petr Ppokop at LOM to see if he can help.
My early 332B did not originally come with this device, but since it is intended to lean the mixture at low RPM, and mine seems to be overly rich, it seems worth a try.
Steve
From: AeroCraftsman <mark(at)aerocraftsman.com (mark(at)aerocraftsman.com)>
Reply-To: <lom-list(at)matronics.com (lom-list(at)matronics.com)>
Date: Monday, May 28, 2012 4:37 PM
To: "lom-list(at)matronics.com (lom-list(at)matronics.com)" <lom-list(at)matronics.com (lom-list(at)matronics.com)>
Subject: Re: 705-1000 manifold pressure regulator
Stephen,
Mark Lightsey
M337C
Quote: | Looking for a 705-1000 regulating valve assembly. This unit fits between the throttle butterfly and the fuel injection pump and is used to regulate the pressures sensed by the fuel injection pump.
Steve
cs.com
com
Posted: Wed May 30, 2012 4:52 am Post subject: 705-1000 manifold pressure regulator |
Petr is who I deal with and he has always been very helpful.
Good luck with it,
Mark
On May 28, 2012, at 1:45 PM, Stephen Beaver <sbeaver(at)columbus.rr.com (sbeaver(at)columbus.rr.com)> wrote:
[quote]Yes. I just emailed Petr Ppokop at LOM to see if he can help.
Steve
Stephen,
Mark Lightsey
M337C
Steve
cs.com
com
cs.com
Posted: Wed May 30, 2012 5:08 am Post subject: 705-1000 manifold pressure regulator |
Update.
It turns out the 705-1000 device is required for later engines only. The M332Sc which I have has a needle valve built into the throttle housing which serves the same purpose, so the regulator is neither needed or approved for this engine.
Steve
Date: Wednesday, May 30, 2012 8:51 AM
Good luck with it,
Mark
Quote: | Yes. I just emailed Petr Ppokop at LOM to see if he can help.
Steve
Stephen,
Mark Lightsey
M337C
Steve
cs.com
com
ronics.com/contribution |
cs.com
com
Posted: Wed May 30, 2012 5:35 am Post subject: 705-1000 manifold pressure regulator |
Hopefully you'll be able to make the necessary adjustments using the needle valve assembly to cure the condition.
Mark
On May 30, 2012, at 6:08 AM, Stephen Beaver <sbeaver(at)columbus.rr.com (sbeaver(at)columbus.rr.com)> wrote:
[quote]Update.
Steve
Good luck with it,
Mark
Steve
Stephen,
Mark Lightsey
M337C
Steve
cs.com
com
cs.com
com
cs.com
