		Tim Olson
				 Posted: Fri Nov 09, 2012 5:50 am    Post subject: Fiberglass Cutting - Vibrating tools |
				Quick query of y'all.  For cutting fiberglass, I know many
 people have recommended those sonic vibrating tools, like
 Fein, SoniCrafter, and others.  Harbor freight has a
 single and variable speed model, and there is a Rockwell
 on sale by me now too.
 Is there any outstanding reason to buy one over the other?
 Has anyone had experience with the Harbor Freight cheap ones?
 How about which blade cuts fiberglass best?
 I'm going to buy one today, for fiberglass cutting, and
 wanted to take some of your recommendations with me.
		aerosport1
				 Posted: Fri Nov 09, 2012 6:06 am    Post subject: Fiberglass Cutting - Vibrating tools |
 I have had the Fein for about 12 years now and it gets used and abused every
 week for something here at work. That being
 Said it is expensive compared to the others. The quality of the Fein is
 outstanding. I think the key here is that
 Some of these tools do not turn the RPM or movement as the Fein. If it is
 20,000 like the Fein then for
 Home use I would get the soniCrafter. The flat 3/4 round thin blades work
 the best for fiberglass cutting. I would
 Recommend a variable speed as well.
 FWIW
 Geoff
 Geoff Combs
 Aerosport Modeling and Design
 8090 howe industrial pkwy
 canal winchester, ohio 43110
 614.834.5227p
 614.834.5230f
 www.aerosportmodeling.com
  _________________ Geoff Combs
 RV-10 QB N829GW
Flying 500 hrs
40033 |
		bcondrey
				 Posted: Fri Nov 09, 2012 6:14 am    Post subject: Fiberglass Cutting - Vibrating tools |
				Tim,
  Other factor is blades - there isn't a single "standard". just make sure you can get the blades you want.  There are at least 2-3 different configurations of how they actually attach to the tool and aren't interchangable.
  FWIW, I've got a Bosch that I found on sale and like it a lot.  They work very well for trimming most stuff but if you're trimming thick material like the cabin top (1/4" or thicker in places) you'll go through blades pretty quickly.
  Bob
  On Fri, Nov 9, 2012 at 8:04 AM, Geoff Combs <g.combs(at)aerosportmodeling.com (g.combs(at)aerosportmodeling.com)> wrote:
  [quote]--> RV10-List message posted by: "Geoff Combs" <g.combs(at)aerosportmodeling.com (g.combs(at)aerosportmodeling.com)>
 FWIW
 Geoff
 Geoff Combs
 614.834.5227p
 614.834.5230f
		davidsoutpost(at)comcast. Guest
				 Posted: Fri Nov 09, 2012 6:17 am    Post subject: Fiberglass Cutting - Vibrating tools |
				I usually can recommend HF for a lot of stuff but have never had good luck with there electric tools.   On the other hand,  I purchased one of their multi tool blades and had very good luck with it.  It was a bi-metal blade.  Works great on fiberglass.  In fact,  I used it yesterday in my Fein and cut out the Skyview holes in my IP and it was still going strong after a whole lot of fiberglass cutting which is really hard on blades.   I would opt for the Rockwell SoniCrafter which Costco has for $79.  Just my humble opinion.
 David Clifford
 RV-10 Builder
 Howell,  MI
 Sent: Friday, November 9, 2012 8:49:10 AM
 Subject: Fiberglass Cutting - Vibrating tools
 --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>
                   -Matt Dralle=====================
		Kelly McMullen
				 Posted: Fri Nov 09, 2012 7:29 am    Post subject: Fiberglass Cutting - Vibrating tools |
				Tim,
 I evaluated one of the cheap HF ones for EAA. Less than 6 months later it failed from switch problems, likely related to overheating. I was able to get a replacement from them, which I still have, but don't use much since I got the initial cabin top and doors trimming done. For smaller jobs I much prefer the fine control of a Dremel cutoff wheel. The HF tool is maybe a bit easier to use than my die grinder with cutoff wheel. Probably doesn't send dust and grit flying as far. Main weakness of HF version IMHO is that it can't take continuous heavy cutting. The straight metal blades wear quickly. The more expensive diamond grit blades don't seem to cut as fast and make a wider cut.
  Kelly
 On Fri, Nov 9, 2012 at 6:49 AM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
 [quote] --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
  om" target="_blank">www.aeroelectric.com
  ooks.com" target="_blank">www.buildersbooks.com
  et="_blank">www.homebuilthelp.com
  le, List Admin.
  http://forums.matronics.com
A&P/IA, EAA Tech Counselor
KCHD |
		rleffler
				 Posted: Fri Nov 09, 2012 7:40 am    Post subject: Re: Fiberglass Cutting - Vibrating tools |
				I have two of the entry level HF multi-function tool.  It's a long story that I won't go into at the moment.
 It would be better if it had a faster speed like the Fein, but I rarely had a problem cutting anything.   The fiberglass on the cabin cover was pretty easy to cut.  I did find that the flat bi-metal half moon blade lasted longer.  I think I went trough blades a whole lot faster than Geoff does with his Fein, but since I don't use it regularly, HF was the less expensive option.
 It's on sale now for $17.99.  Hard to beat at that price.
 I debated about upgrading to the faster unit from HF or another vendor, but couldn't justify the expense since the one I had worked.
 bob
  _________________ Bob Leffler
N410BL - Phase I
		Tim Olson
				 Posted: Fri Nov 09, 2012 8:02 am    Post subject: Fiberglass Cutting - Vibrating tools |
				Thanks guys for all of the feedback from all 5 of you
 so far.
 There are times when you buy tools to last a long time,
 and times when you buy a tool for a few jobs.  This one I
 was mixed on.  I'd like to have it last, because I did
 order my RV-14 kit and may want to use it on that build.
 But, what I need it for TODAY is cutting a fibergalss
 bathtub out of the house.
 As Bob says, the HF cheap single speed is $17.99
 right now.  Their variable speed model "Pro" one
 is $34.99.  Then there's the Rockwell SoniCrafter
 that's $99 right now in our local stores.
 Ultimately, it's worth $18 just to get the dang tub
 cut out, so the HF one could be fine, but, I have
 a hard time sometimes buying a cheap tool, so I'm still
 on the fence. The RV-14 doesn't have nearly the amount
 of fiberglass to deal with (Woo Hoo!!), but it may come
 in handy on the cowl and some other parts.  Like Kelly,
 I used a cutoff wheel on the RV-10 a lot, and that worked
 well.  I used the air powered tools more though.
 I just remember being COVERED in fiberglass when I got
 done, so for tonights job I just KNOW I want to use a
 vibrating tool.  I guess I'll have to actually go
 to HF today and put one in my hands, and see what
 accessories it includes.  As Bob mentioned, the blades
 are important too, and I'll have to compare which one
 will cost me more to use in the long run, especially
 since the job is fiberglass and the blades will add up.
 Dave, you talked about not having luck with HF for
 electric tools, but said you used their blades in your
 Fein.  So the HF Blades work fine in a Fein then, eh?
 I don't think I'll spend that kind of money on the
 tool, but I wonder if the HF blades would work on the
 SoniCrafter...
 Still got to think about it. Maybe some google time
 will help.  I figured this would be a good discussion
 for RV-10 builders looking for the tool too, since
 that is where I first heard that these things are
 good for fiberglass. I sure wish I would have had
 one when I was doing the -10.  If I were doing another
 -10, I'd probably consider a Fein or at least real
 nice copy.
 On 11/9/2012 9:40 AM, rleffler wrote:
  bob
				 Posted: Fri Nov 09, 2012 8:07 am    Post subject: Fiberglass Cutting - Vibrating tools |
				The key to using one of the multi-tools is the blade.  The HSS blades will not cut good and will not last.  Spend the extra few dollars and purchase the bi-metal blades.  We built 2 Cozy MKIV planes and used only 2 bi-metal blades,  Fein Bi-metal at $70 each way back when.  That's a whole lot of fiberglass cutting with only 2 blades.  The bi-metal blade I purchased from HF was only about $14 IIRC and the quality of that blades is very good.  It fit the Fein just fine and most of the multi-tools out there now use universal mounting systems.  I believe that the Bosch uses its own though.  The variable speed control is a must have for doing different things.  The Fein was about $400 way back when we purchased it and gets used quite often in and out of the shop.   They are half the price now.  Good tools that you plan to keep are well worth the extra cost.  I would not hesitate to purchase the Rockwell kit (at) $79 from Costco.  It is a well built product that will last.
 David Clifford
 RV-10 Builder
 Howell,  MI
 Sent: Friday, November 9, 2012 10:40:36 AM
 Subject: Re: Fiberglass Cutting - Vibrating tools
 --> RV10-List message posted by: "rleffler" <rv(at)thelefflers.com>
 bob
 Bob Leffler
 N410BL - Paint - 90% done, 90% to go stage
 RV-10 #40684
 http://forums.matronics.com/viewtopic.php?p=387368#387368
 <=           (And Get Some AWESOME FREE Gifts!)
		flying-nut(at)cfl.rr.com Guest
				 Posted: Fri Nov 09, 2012 8:38 am    Post subject: Fiberglass Cutting - Vibrating tools |
				On 11/9/2012 11:02 AM, Tim Olson wrote:
  so far.
 I used a coarse blade in the HF reciprocating saw (like a Sawzall) to
 cut out a FG shower.  Made quick work of it.
 Linn
		robin(at)PaintTheWeb.com Guest
				 Posted: Fri Nov 09, 2012 9:18 am    Post subject: Fiberglass Cutting - Vibrating tools |
				Just be happy you have a fiberglass tub vs. a cast iron tub. The crew charged with removing a large cast iron tub from our upstairs master had to cut it in half. The mayhem included breaking two picture windows with flying metal chunks.
 BTW the only issue with the tub was that it was peach in color. Had to go!
 Robin
		ngeorge(at)continentalmot Guest
				 Posted: Fri Nov 09, 2012 9:24 am    Post subject: Fiberglass Cutting - Vibrating tools |
				You don't have an axe?  Or a sawsall?
 neal
		Lew Gallagher
				 Posted: Fri Nov 09, 2012 9:26 am    Post subject: Fiberglass Cutting - Vibrating tools |
				Hey Tim,
 Just a thought or two.  For the thinner cowl type cutting (your next
 project -- awesome), I always use sheers (same ones as on aluminum) -- no
 dust, no kerf, easy to final touch up with a belt sander.  For tub removal
 where finesse is the least concern, I use a sawsall with a course blade and
 have at it!  I'll be doing that soon to the tub/shower I built the room
 around 26 years ago.
 Later, - Lew
  _________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
		rv10flyer(at)live.com Guest
				 Posted: Fri Nov 09, 2012 9:42 am    Post subject: Fiberglass Cutting - Vibrating tools |
				I gather painting it was never a consideration? (LOL)
		wgreenley
  Joined: 09 Jan 2010 Posts: 100 Location: Dowagiac, MI
				 Posted: Fri Nov 09, 2012 10:20 am    Post subject: Fiberglass Cutting - Vibrating tools |
				Actually, there are companies that resurface bathtubs in place. My dad had a
 franchise and did that for a number of years before he retired. He often did
 tubs and sinks, could even do tile. The homeowner would then put in a new
 matching stool. New look without the destruction. The process would also
 totally seal the grouting in any tile.
 Bill
		Tim Olson
				 Posted: Fri Nov 09, 2012 1:17 pm    Post subject: Fiberglass Cutting - Vibrating tools |
				To circle back on the tool thing....I did end up getting the
 Harbor Freight tool.  I got it with a coupon for $34.99
 for the variable speed version, which does do 20K RPM.
 I also bought a diamond blade, a couple extra wood/metal
 circle blades, and a better pluger blade in addition to the
 one that came with it.  I bought the $9.99 2 yr warranty
 too.  It was $95 tax included, with all the extras.
 I read a few reviews of the HF one, and basically it
 was comparable in quality to the Rockwell.  People said
 the old single speed was junk, but the variable was
 very nice and they used it for tons of things.  Some
 did have problems, but with the added warranty they
 said they'd go that route because if something goes wrong
 you just bring it in and grab a new one.  So for the
 money, it was a good way to go.  The blades, incidentally,
 say they're good for Fein, Rockwell, Bosch, and all of the
 brands, so they must be very similar.  So if it works,
 it should be good for me.  If I have any real positive
 or negative comments I'll circle back and give them to
 you.
 I'm just glad the tub wasn't peach like Robins...but it
 is an awful gold color from the 70's.  Resurfacing isn't
 something I'd like, but Neil's idea of the axe makes
 the project sound fun!
 On the topic of RV-14...a couple have asked "Why?".
 Well, I have a crystal ball.  My crystal ball tells
 me that my kids will not want to travel with us when
 they are 15-18 years old unless they have friends with
 them.  We only have a 4-seat plane.  This gives us
 6 seats of capacity for X/C trips, with 2 planes
 with similar speeds and ranges.  But, it does a couple
 other things.... it gives the kids a plane to learn
 in, it gives a fun plane for local flights, and it
 gives me an aerobatic plane to play in.  It's a toy
 plane, and one that I'm only planning to keep for
 maybe 10 years.  It's "disposable".  My RV-10 will
 probably never be sold.  This one I'll probably try
 to get partners in, too.  So I won't be quite as
 attached to this plane (I think), but it should be
 a lot of fun!
				 Posted: Fri Nov 09, 2012 2:09 pm    Post subject: Fiberglass Cutting - Vibrating tools |
				Re the saw.  I'll be interested in reading your review somewhere down
 the line.
 I felt like I tried 'everything' when I was at the FG top phase. I did
 get a version of the vibrating tool.  Honestly, after a week of
 experimentation, it collected dust for the last 3 years.  I need a demo
 or something.
 I went thru 2 HF air powered recip saws.  They worked until they
 failed.  I think you used these too.  Cheap but hard to control
 precisely.  I did cut my landing light hole out with one and survived
 the experience.
 One thing worked very well for me and that is the Sawzall type of recip
 saws with a custom blade.  Maybe this is what you meant by a diamond
 blade, maybe the bi metal, I don't know.  But What I got was an abrasive
 type of blade and cut it length-wise so that it could turn tighter
 corners.  The (diamond?) abrasive cuts much better than any toothed
 blade, it's easy to handle even on a big recip Sawzall,  and it lasts.
 Based on that experience, I try to avoid using my bladed tools on any
 fiberglass.  Abrasive countersinks are particularly effective too.  But
 you probably know all that already.
 Anyway, thanks for sharing your reasons for the '14.  Fantastic!
 Bill
 On 11/9/2012 4:16 PM, Tim Olson wrote:
  you.
  a lot of fun!
		Tim Olson
				 Posted: Fri Nov 09, 2012 4:38 pm    Post subject: Fiberglass Cutting - Vibrating tools |
				OK, I've used the tool a bit now, so I can at least give
 preliminary comments on it.  I think that if you hold a
 steady hand, you can do some pretty good straight cuts with
 the tool.  The standard 3/4 round blades cut pretty well and you
 could rough cut with them and file it to finish for any
 fiberglass work you do.  It isn't nearly as fast as the
 rough blade sawsall, but you won't find anything to use a
 sawsall on for a plane anyway.  The blade seemed to last a
 pretty good amount of time.  The glass was nearly 1/4" thick
 and I probably cut 25' or more of distance with it.  It's
 pretty worn down now.  But, if you were trimming wingtips
 or something, it seems like it wouldn't do a bad job at all.
 (just a guess since I wasn't trimming wingtips)  The HF tool
 didn't have any operational problems and I did run it until
 it got pretty darn warm and then gave it a break. It does come
 with new brushes, which many tools don't, so that's a plus.
 All in all, I'm glad I bought it....it was real comforting
 when cutting into the area that had electrical and network
 wiring behind it....I didn't have to worry about wrecking
 something too bad.  It was also safer than the sawsall when
 moving my hands near the cutter.
 So, I'm sure there are better tools, like the Fein or some
 good name brands, but this one seems like it would survive
 an RV-10 build for the small amount of cutting you'd do
 with it.
 Tim Olson - RV-10 N104CD
 On 11/9/2012 3:16 PM, Tim Olson wrote:
  you.
  a lot of fun!
		Tim Olson
				 Posted: Fri Nov 09, 2012 4:46 pm    Post subject: Fiberglass Cutting - Vibrating tools |
				PS: The biggest benefit?  There was very little dust compared to
 other cutting methods.  The sawsall made a mess.  The oscillating
 tool was not bad.
 On 11/9/2012 6:37 PM, Tim Olson wrote:
  with it.
 > you.
 > a lot of fun!
 > Tim
		jeff(at)westcottpress.com Guest
				 Posted: Fri Nov 09, 2012 5:16 pm    Post subject: Fiberglass Cutting - Vibrating tools |
				My Fein tool allows for a vacuum attachment, though it's a bit cumbersome to use that way
 Jeff Carpenter
 40304
 Painting
 On Nov 9, 2012, at 4:46 PM, Tim Olson wrote:
  tool was not bad.
 > with it.
 >> you.
 >> a lot of fun!
 >> Tim
		Kellym
				 Posted: Fri Nov 09, 2012 6:31 pm    Post subject: Fiberglass Cutting - Vibrating tools |
				I imagine with your experience now, and no forming of parts, and all
 holes already final size, you can probably whip it out over the winter, eh?
 Beats wasting time shoveling the driveway...just stay inside in the shop
 and telecommute to work when they NEED your expertise.
 On 11/9/2012 2:16 PM, Tim Olson wrote:
  you.
  a lot of fun!
 Checked by AVG - www.avg.com
KCHD |
