Nippondenso
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List
ghfrost(at)earthlink.net
PostPosted: Mon Jun 05, 2006 6:08 am    Post subject: Nippondenso Reply with quote
Hi,
My Nippondenso altrnator was charging at 14.9 max. I was unable to get
info from Duralast ( the rebuilder), Toyata dealers, Matronics RV site,
and some A&Ps re: the proper wiring. I had a wire to the field post but
none to the sense post. With the help of my son, and a NAPA dealer, the
sense wire now goes to the output post and Voila! max charge is 14.2.
I thought this might help someone else.
George
- The Matronics RV6-List Email Forum -
http://www.matronics.com/Navigator?RV6-List
CustomACProp(at)aol.com
PostPosted: Tue Jun 06, 2006 8:45 pm    Post subject: Nippondenso Reply with quote
Hi George,
It worked for me.  I had the same symptom and found I didn't have the sense wire installed.
14.9 went to 14.2 volts.
Jim Ayers
RV-6A 54 hrs TT 19 hours remaining on 25 hour Phase 1.  Don't ask.
In a message dated 06/05/2006 11:59:11 PM Pacific Daylight Time, rv6-list(at)matronics.com writes:
Time: 07:08:36 AM PST US
Subject: Nippondenso
--> RV6-List message posted by: George Frost <ghfrost(at)earthlink.net>
Hi,
George
k9hxt(at)sbcglobal.net
PostPosted: Wed Jun 14, 2006 6:45 am    Post subject: Nippondenso Reply with quote
I believe (from memory) there are two pins on the plug and one output terminal, so which one is the sense wire? One pin is the field, one is the fault light, and....?   It has been a while since I wired mine.   May have "faulty" memory.....<:
Larry, RV-6A
"LIMA TANGO SENDS"
PostPosted: Thu Jun 15, 2006 11:02 am    Post subject: Nippondenso Reply with quote
My regulator on my Nippondenso is NAPA UR572SB. There are three pins.
Two are parallel and vertical, one is perpendicular and horizontal. The
perpendicular pin is above the parallel pins. It is the sense pin.
With the sense pin located above the parallel pins, the left pin is the
field pin and the right pin is for the automatic choke according to
NAPA dealer info. We, of course have no automatic choke so it is not
used. Left pin field wire from bus, top pin sense wire to output post.
It works that way.
On Jun 14, 2006, at 10:43 AM, Larry Rush wrote:
[quote] I believe (from memory) there are two pins on the plug and one output
Larry, RV-6A
"LIMA TANGO SENDS"
PostPosted: Fri Jun 16, 2006 6:11 am    Post subject: Nippondenso Reply with quote
Thanks George............
"LIMA TANGO SENDS"
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List All times are GMT - 8 Hours
