PFolbrecht(at)starkinvest Guest
Posted: Mon Jun 05, 2006 9:27 am Post subject: Dimpling Boo-boo |
A couple days ago I was dimpling elevator skins with the C-frame. My helper’s hand, pulling back the skin, slipped and it popped out of the male die as the mallet was coming down, creating a new dimple/hole about .20” from the existing hole. I pounded it out with a hammer on a steel backrivet plate, but the hole from the dimple die is still there.
I would consider this to be not too big a deal (I hope). Perhaps a dab of tank sealant on the underside of the skin would be a good idea to prevent a vibration-crack from forming? There must be SOP for this sort of thing?
Paul
9A QB #1176
gerf(at)gerf.com Guest
Posted: Mon Jun 05, 2006 10:02 am Post subject: Dimpling Boo-boo |
He he ... I'll give you a cent to a dollar it won't be the last
I think I've got about 3 of those so far. The general
wisdom I've heard is to flatten it out and move on, its more of
a cosmetic issue than a structural one ...
g
| Quote: | A couple days ago I was dimpling elevator skins with the C-frame. My
helper's hand, pulling back the skin, slipped and it popped out of the
..20" from the existing hole. I pounded it out with a hammer on a steel
of thing?
Paul
9A QB #1176
__g__
Gerry Filby gerf(at)gerf.com
Tel: 415 203 9177
Posted: Mon Jun 05, 2006 10:47 am Post subject: Dimpling Boo-boo |
Folbrecht, Paul wrote:
Paul
9A QB #1176
| I haven't gone this route, but unless the "new" dimple severely impacted the correct dimple, I would leave it dimpled. It would make it much easier to fill with whatever body putty you use' As for stress crack, I'd just clean up the edges of the new (dimpled) hole.
Linn Lots of rivets, but none in my -10 yet!
jjessen
Posted: Mon Jun 05, 2006 11:13 am Post subject: Dimpling Boo-boo |
I would have left it dimpled and inserted a rivet. Let the painters cover up the mistake. And, welcome to the club!
John J
RV-10 Tailcone
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of linn Walters
Sent: Monday, June 05, 2006 11:48 AM
To: rv-list(at)matronics.com
Subject: Re: Dimpling Boo-boo
| Quote: | (at)page Section1 {size: 8.5in 11.0in; margin: 1.0in 1.25in 1.0in 1.25in; } P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } A:link { COLOR: blue; TEXT-DECORATION: underline } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline } A:visited { COLOR: purple; TEXT-DECORATION: underline } SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline } SPAN.EmailStyle17 { COLOR: windowtext; FONT-FAMILY: Arial; mso-style-type: personal-compose } DIV.Section1 { page: Section1 }
Paul
9A QB #1176
Well, I'm nearly done with the emp., and I have a QB kit, so there is
not much dimpling remaining! :-}
This is why I should check the list before I do anything. ;-} I pounded it out immediately afterward without thinking it through completely… hey, it looked better.
Sent: Monday, June 05, 2006 1:48 PM
Paul
9A QB #1176
derek(at)sington.net Guest
Posted: Mon Jun 05, 2006 12:02 pm Post subject: Dimpling Boo-boo |
Paul,
I know exactly what you mean. I did exactly the same on an elevator skin, and tried to weave the hole into a much bigger one for a huge rivet… Consequently I created a rather large crack and had to get a new skin. That said, I’m glad I did, as I know that every time I would have looked at that elevator I would have wished I hadn’t been such a fool. Question is this, therefore; is it on the upper or lower surface?
Derek.
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Folbrecht, Paul
Sent: 05 June 2006 20:13
Subject: RE: Dimpling Boo-boo
Paul
9A QB #1176
jim jewell
Joined: 09 Jan 2006 Posts: 82 Location: Kelowna B.C. Canada
Posted: Tue Jun 06, 2006 11:09 pm Post subject: Dimpling Boo-boo |
Paul,
Redimple the hole put a rivet in it and cary on McDuff.
Keep building,
Jim in Kelowna do not archive
_________________ "I never make mistreaks" |
lifeofreiley2003(at)yahoo Guest
Posted: Wed Jun 07, 2006 7:15 am Post subject: Dimpling Boo-boo |
Aah yes... been there and done that. I would follow Jim's suggestion as well.
Darrell
Jim Jewell <jjewell(at)telus.net> wrote:
[quote] (at)page Section1 {size: 8.5in 11.0in; margin: 1.0in 1.25in 1.0in 1.25in; } P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } A:link { COLOR: blue; TEXT-DECORATION: underline } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline } A:visited { COLOR: purple; TEXT-DECORATION: underline } SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline } SPAN.EmailStyle17 { COLOR: windowtext; FONT-FAMILY: Arial; mso-style-type: personal-compose } DIV.Section1 { page: Section1 } Paul,
Keep building,
jhstarn(at)verizon.net Guest
Posted: Wed Jun 07, 2006 8:33 am Post subject: Dimpling Boo-boo |
While building the rudder (RV-4) for the HRII we drilled an accidentally an extra hole on one side beyond the end of the rib. Sooo we drilled a matching hole on the other side too. Put rivets in both and when ask about the "extra" rivets by other -4 builders we would respond: "You didn't the emergency AD ?". Same guys ask how we got the 3 burner camp stove in the Rocket at OSH. Answer was simple: We put it one of the wing tip lockers. You would be surprised by the number of people what checked out the locker door size. Do Not Archive KABONG
Don't stress out about a rivet, most real problems are caused by the loose nut with his/her hand on the stick. (pun intended)
| Quote: | Subject: Re: Dimpling Boo-boo
Darrell
Jim Jewell <jjewell(at)telus.net (jjewell(at)telus.net)> wrote:
| Quote: | (at)page Section1 {size: 8.5in 11.0in; margin: 1.0in 1.25in 1.0in 1.25in; } P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } A:link { COLOR: blue; TEXT-DECORATION: underline } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline } A:visited { COLOR: purple; TEXT-DECORATION: underline } SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline } SPAN.EmailStyle17 { COLOR: windowtext; FONT-FAMILY: Arial; mso-style-type: personal-compose } DIV.Section1 { page: Section1 } Paul,
Keep building,
