tmoushon(at)gmail.com Guest
Posted: Sun Nov 11, 2012 12:07 pm Post subject: Elevator skin |
Steve, i just finished my elevators today for the RV 10....so I am new at this. Couple points to this. First, the elevator skin goes on top so that you have access to four key rivets on the front spar and can buck the two rivets on the upper skin. After attaching the rib tip assembly you should close the top skin first because the bottom skin uses two pop rivets that don't requiring bucking.
RV 10 builders.... Short note of thanks. I posted a note a couple months ago asking for help with a test flight. Not only did I recieve quite a few responses... Dick Sipp and his wife Vicky stopped by on their way home to Michigan at the end of September and gave me and my wife a wonderful flight.... I ordered the 10 the next day. Most of my questions to date have been answered by the great notes from Matronics as well as the great tips in the building process found on various web sites. In my build I alumiprep, alodine and two part epoxy paint... I installed a Ray Allen wire in the rudder and cut in an access plat for future use.... ALL of these great ideas coming from this team...so THANK YOU. I hope to learn more...and give back some day... Again, my sincere thanks! My call sign changed from " builder want-to-be". It is now builder #41393. Terry.
