air.guerner(at)wanadoo.fr Guest
Posted: Sat Jun 03, 2006 11:51 am Post subject: Airmaster prop adjustment |
Hello all,
I recently installed an Airmaster prop. I have increased the coarse pitch limit twice. Coarse blade angle is now 24 degrees 15 minutes measured at the tip and needs to be increased again. I would like to know what coarse limit the others with Monowheel/912S are flying with.
Remi Guerner
F-PGKL, XS S/N395 monowheel, 912S, Airmaster, 391 hours
daseitz(at)cfl.rr.com Guest
Posted: Sun Jun 04, 2006 12:05 pm Post subject: Airmaster prop adjustment |
I have adjusted mine once to get more coarse. Not sure what the coarse pitch
is right now but I had noticed flying straight and level that about 32 inchs
manifold pressure got the prop to full coarse limit. I haven't seen it go to
full coarse since but have not been pushing it real hard since at 5000 ft I
have to run at less than 50% power to stay with them. At 5000 ft I've been
seeing 145 kts at 65% or less.
Dean Seitz
N284A Europa XS tri gear 914 Airmaster
91 hrs so far
paul.mcallister
Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
Posted: Sun Jun 04, 2006 2:03 pm Post subject: Airmaster prop adjustment |
| Quote: | At 5000 ft I've been seeing 145 kts at 65% or less.
| Quote: | Dean Seitz
91 hrs so far
Hi Dean,
Can you tell me the MP (at) RPM setting that you see that correlates to 65% ?
Is the 5000' value you have derived after compensating for barometric
pressure and temperature ?
How are you verifying your speed, 3 or 4 axis runs, or some other method.
Thanks, Paul
Posted: Sun Jun 04, 2006 2:24 pm Post subject: Airmaster prop adjustment |
I'm going by the rotax chart that shows 75% power is 31" MP and 5000rpm and
if I'm not mistaken 65% is 30" mp. I don't have the book with me right now.
The 5000' is right off the altimeter set at the closest airport altimeter
setting. Yesyerday we were at 6500' showing around 135 knots, to fly with a
Piper Archer and the MP was back to approximately 28" at 5000rpm.
Dean Seitz
Posted: Sun Jun 04, 2006 2:25 pm Post subject: Airmaster prop adjustment |
I checked the speed a couple times with the three runs at more than 90 deg.
apart spreadsheet. Also was comparing groundspeed and airspeed with the
Archer we were flying with.
Dean
garrys(at)tampabay.rr.com Guest
Posted: Sun Jun 04, 2006 2:59 pm Post subject: Airmaster prop adjustment |
Dean,
At 30" MP and 5000 RPM a Europa is roughly a 125 Kt airplane at sea level.
To what do you attribute your amazing performance?
Garry Stout
914 Tri w/whirlwind prop & 450 hours.
Posted: Sun Jun 04, 2006 3:22 pm Post subject: Airmaster prop adjustment |
Hi Dean,
Those numbers are most impressive.
If they are confirmed, then you're doing better than most Europas, and
even faster than the smaller and lighter MCR 01 with its diminutive
laminar flow wing.
Honest, I would have expected this power setting would yield the same
numbers, but in mph. 145 mph is about 126 kt, quite in accordance with
what I heard about the Europa.
I'd be interested in learning more about your speed measurements, and
the mods you performed on the aircraft : any cooling drag reduction,
hiding antennas, work on the wing, etc.
Gilles Thesee
Grenoble, France
http://contrails.free.fr
SPurpura(at)aol.com Guest
Wow 145KTS (at) 65% is incredible for even IAS at that power setting,are you sure about that,my 914 mono would be about 110KTS IAS at 65% power
Posted: Sun Jun 04, 2006 3:23 pm Post subject: Airmaster prop adjustment |
Yes, at sea level mine is doing 130 kts at 31" mp. At higher alt is is
performing really nice. I haven't been flying too much at high alt but the
last few weeks been flying with other planes at 5000 to 7500 ft and notice a
big difference in speed.
Dean
paul.mcallister
Posted: Sun Jun 04, 2006 4:52 pm Post subject: Airmaster prop adjustment |
Hi all,
The only charts I have found for the 914 are a real "magnifying glass job"
and I have a heck of a time trying to do the interpolations
I'd be interested in what folks think 28" (at) 5000 RPM is in % of power. I
have always though it was 65%, but I am not really sure.
Paul
Posted: Mon Jun 05, 2006 12:43 pm Post subject: Airmaster prop adjustment |
Here are the numbers out of the rotax operators manual:
Takeoff power 5800rpm 39"mp
Max cont power 5500rpm 35"mp
75% power 5000rpm 31"mp
65% power 4800rpm 29"mp
55% power 4300rpm 28"mp
I did once see another chart in the book that differed a little on the rpm's
but can't find it now.
Ever since I installed the wheel and leg fairings its flown a constant
130kts at sea level to around 2000'. If weather permits I'll go up around
7500' this weekend and see what the different power setting give in speed.
Although I always fly at cruise on the prop which is 5000rpm.
I do not have the europa speed kit. My main gear wheels are from aircraft
spruce and I made the nose wheel and all the leg fairings.
Dean Seitz
N284A
paul.mcallister
Posted: Mon Jun 05, 2006 4:26 pm Post subject: Airmaster prop adjustment |
Dean,
That helps, sort of. I have a constant speed prop, and during cruise I run
at 5000 rpm, however from the charts I have I find it difficult to
interpolate what % power settings MP's from 24" through to 34" would
actually translate to.
I suspect that you are looking at a larger chart than the small one in the
engine logbook. If so, are you able to tell me the following:
34" (at) 5000 rpm = xx%
33" (at) 5000 rpm = yy%
32" (at) 5000 rpm = ww%
24" (at) 5000 rpm = zz%
Thanks, Paul
do not archive.
