bob.verwey(at)gmail.com Guest
Posted: Mon Nov 26, 2012 4:49 am Post subject: Which leads for Alcor EGT? |
Gents,I have a mint condition Elcor Ekonomix instrument plus Alcor 9411 probe p/n 86245. I do not have the leads to connect the two!
The setup tests fine when the probe is connected directly to the gauge, although I am not to sure about the calibration without the leads.
Can anyone tell me an easy way to set up 4 ft leads that would work please?
Bob Verwey
Posted: Mon Nov 26, 2012 11:08 am Post subject: Which leads for Alcor EGT? |
According to this data sheet on Alcor's website
http://tinyurl.com/d4y7pdu
your probe is a type K device. You can fabricate
an type-K extension lead from the appropriate
wire but depending on your locale, it may
be hard to find. It should be crafted from stranded
type-K wire.
The factory offerings for extension cables
are ridiculously long for an SE aircraft
http://tinyurl.com/cj29577
You can order a small quanity of 20AWG stranded
K wire for $33 from Omega
http://tinyurl.com/2fpp8r
cut it to appropriate length and install PIDG
terminals to make the connections.
Posted: Tue Nov 27, 2012 12:15 am Post subject: Which leads for Alcor EGT? |
Much obliged to you, Sir!
Best...
Bob Verwey
On 26 November 2012 21:07, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
� According to this data sheet on Alcor's website
� your probe is a type K device. You can fabricate
� an type-K extension lead from the appropriate
� wire but depending on your locale, it may
� be hard to find. It should be crafted from stranded
� type-K wire.
� The factory offerings for extension cables
� are ridiculously long for an SE aircraft
� �You can order a small quanity of 20AWG stranded
� �K wire for $33 from Omega
� �cut it to appropriate length and install PIDG
� �terminals to make the connections.
� Bob . . .
om" target="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
