Charlotte NC routing to Chicago area
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV4-List
Jerry Grimmonpre'
PostPosted: Tue Jun 06, 2006 4:43 pm    Post subject: Charlotte NC routing to Chicago area Reply with quote
Hi RV4 Listers ..
I just purchased Ron Awad's RV-4 and will soon fly it from the East side of
Charlotte NC to just West of Chicago O'hare area. I'm wanting to know which
direction most of you would fly heading out of Charlotte. Would you go
South of Charlotte and make an end run around the mountains or would you go
over the pass at Ashville and head straight out for a direct course to
Chicago area? The airplane is VFR only so it's a given that the ground has
to be visible.
I'll make two stops for fuel not more than 300 miles at a time. Any
suggested places to stop or avoid. The first stop will be an over night so
it'd be nice to have it close to a hotel (town area).
Crosswind landings ... what should a newbie pilot (in the 4) avoid in the
way of maximum wind velocity for cross? Any other suggestions that would
help?
Many thanks ...
Jerry Grimmonpre'
- The Matronics RV4-List Email Forum -
http://www.matronics.com/Navigator?RV4-List
sawad13(at)msn.com
PostPosted: Tue Jun 06, 2006 4:59 pm    Post subject: Charlotte NC routing to Chicago area Reply with quote
Hi Jerry, have you flown in that RV-6 taildragger yet? If so how did you do?
I think the RV 4 can handle quite high cross winds, and I find it to be a
easy plane as far as taildraggers go. But you do got to work those pedals
like any taildragger!
Ron Awad
Reply-To: rv4-list(at)matronics.com
To: <Rv4-list(at)matronics.com>
Subject: Charlotte NC routing to Chicago area
Date: Tue, 6 Jun 2006 19:40:38 -0500
Hi RV4 Listers ..
which direction most of you would fly heading out of Charlotte. Would you
go South of Charlotte and make an end run around the mountains or would you
go over the pass at Ashville and head straight out for a direct course to
to be visible.
help?
Many thanks ...
Jerry Grimmonpre'
http://wiki.matronics.com
ceengland(at)bellsouth.ne
PostPosted: Wed Jun 07, 2006 5:13 pm    Post subject: Charlotte NC routing to Chicago area Reply with quote
Jerry Grimmonpre wrote:
Hi RV4 Listers ..
side of Charlotte NC to just West of Chicago O'hare area. I'm wanting
to know which direction most of you would fly heading out of
Charlotte. Would you go South of Charlotte and make an end run around
the mountains or would you go over the pass at Ashville and head
straight out for a direct course to Chicago area? The airplane is VFR
only so it's a given that the ground has to be visible.
night so it'd be nice to have it close to a hotel (town area).
the way of maximum wind velocity for cross? Any other suggestions
that would help?
Many thanks ...
Jerry Grimmonpre'
This VFR flatlander has flown from MS to Greensboro several times. If
it's clear, flying over is beautiful. Just remember that there's a
reason they call 'em 'Smoky'. It's stressful for me if there isn't much
margin between peaks & clouds. I've gone around a couple of times.
IIRC, the southern end of the pointy stuff isn't very far south of the
Charlotte class B. Probably wouldn't be a huge deviation, if needed.
Charlie
Slobovia Outernational Airport
flying -4, -7 fuselage
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV4-List All times are GMT - 8 Hours
