DCS317(at)aol.com Guest
Posted: Tue Nov 27, 2012 12:28 pm Post subject: LED strip project |
Bob,
How's this project going? I'm interested!
Don
Bob stated on 8-1-12:
I'm going to be using about 80 feet of this product in
my kitchen to put double rows of ceiling accent lighting high up,
double rows to replace recessed canister lights over the
counters and a third twin-row installation under the cabinets
for work lighting. The double-rows will be wired in series to run
off 24 volt supplies in the walls. My present lighting
is fraught with hot-spots from 11 different fixtures with
no accent lighting on a budget of about 700 watts. The working
end of my kitchen will be nicely lighted for both appearance
and working illumination on a power budget of about 175
watts total. This technique produces very wide-angle
illumination that is virtually shadow free.
Posted: Tue Nov 27, 2012 12:56 pm Post subject: LED strip project |
At 02:27 PM 11/27/2012, you wrote:
| Quote: | Bob,
Don
No real fast. End-of-year commitments and all . . .
I have acquired some Formica counter top material
which I cut into 1" wide strips. I plan to build
assemblies of strip lamps onto these strips.
I need five L-shaped assemblies that take the lighting
around corners. If these can be pre-assembled
into a rigid shape for both wiring and spacing
of the led-strips, they'll be easier to install
on the bottoms of the cabinets. They'll also
be easier to remove for maintenance such as
painting and some not too distant remodeling
in the plans.
When I get ready to put them together and
installed, I'll take photos of the process and
post them to the website.
Bob . . . [quote][b]
