SIDESLIP
Posted: Wed Nov 28, 2012 6:56 am Post subject: VDO Fuel gauge wild reading... |
Hello all...
Got another little "issue". I've got the 912 gauges in my 601XL-B. I've got a single fuel gauge with a left/right tank switch. When flipped to the right tank, the needle slowly winds its way past 1/1. Bad ground? Bad sender? It's a top mounted sending unit, but that is the extent of my knowledge on this subject. If it was a bad ground, would the needle not slam itself to its full swing past full? The fact it takes a bit has me wondering.
Thanks in advance!
Chad
_________________ C-GYXQ. 912ULS. 601XL-B |
Posted: Wed Nov 28, 2012 2:20 pm Post subject: VDO Fuel gauge wild reading... |
At 08:56 AM 11/28/2012, you wrote:
Hello all...
Get out your ohmmeter and find the DIFFERENCE
between the two senders. The slow motion of the
gauge is not uncommon. At Cessna back in the 60's
we 'dopped' the pivots on Stewart Warner gauge
clusters with a drop of high viscosity silicon
oil. This didn't affect accuracy but it stopped
needle jitter due to mechanical and/or electrical
stimulus.
( -Thomas Paine 1776- )
SIDESLIP
Posted: Wed Nov 28, 2012 3:28 pm Post subject: Re: VDO Fuel gauge wild reading... |
Difference? Well, the tanks are full, so the only thing I could establish MAYBE, is the current resistance at the gauge for each of the senders.
Is that what you mean?
Thanks Bob!
Chad
Posted: Wed Nov 28, 2012 6:21 pm Post subject: VDO Fuel gauge wild reading... |
At 05:28 PM 11/28/2012, you wrote:
the senders.
Sure. You have one side that reads
right, the other one wrong. The only
difference is their position on the
selector switch. So in comparing the two
sides with each other, one of them has
a loose connection, bad sender resistance,
or perhaps the switch itself is bad.
Having one side that works and one that
doesn't really narrows down the possibilities
and offers the opportunity for comparative
analysis.
