Instrument Panel Cutting
dean.psiropoulos(at)veriz
PostPosted: Tue Jun 06, 2006 9:56 pm    Post subject: Instrument Panel Cutting Reply with quote
Just a quick thanks to all of you folks you responded to my quest for the
optimum methods for cutting holes in the instrument panel (that are not of
the round variety). After experimenting with several different things, I
found that a (baby size) router used for laminate trimming worked the best
for me. I made a wooden jig for the two rectangular holes needed for the
EFIS and AOA mounting and the results turned out very nice, almost as good a
as a CNC milling machine. Round instrument holes were cut with the common
fly cutter and came out nice as well, I just had to adjust the damn thing
for each my 2.5 inch instruments as they didn't seem to be a common size!
I solved my problem of the funny VM1000 engine monitor display cutout by
sending my blank to Mr Steve Davis of Memphis Tennessee (phone number
901-240-3068). Steve has autocad AND machining facilities and has done some
very nice work on RV panels. He did a very nice job on my cutout and the
price was VERY reasonable, it saved me a lot of work and disappointment. I
highly recommend letting Steve do your panel if you have the resources.
I've spent the better part of the last month (spare time) doing the flight
instrument side of the panel and it was a lot more work than I expected (I
have lots of stuff in there though). I enjoyed doing it but could be
further along towards clearing the prop if I'd let someone else do that part
of it. Oh well, I'll be able to say I built EVERYTHING on the airplane
except the metal stampings. Oh the joys and frustrations of building your
own aircraft!!
Dean Psiropoulos
RV-6A N197DM
Not long to- Clear-the-prop
sdavis12(at)midsouth.rr.c
PostPosted: Tue Jun 06, 2006 11:22 pm    Post subject: Instrument Panel Cutting Reply with quote
Thanks Dean!!!
Steve
Mark Phillips in TN
PostPosted: Wed Jun 07, 2006 4:22 am    Post subject: Instrument Panel Cutting Reply with quote
In a message dated 6/7/06 12:58:42 AM Central Daylight Time, dean.psiropoulos(at)verizon.net writes:
I'll second Deans nomination!
Mark Phillips
From The PossumWorks...
pbesing(at)yahoo.com
PostPosted: Wed Jun 07, 2006 8:53 am    Post subject: Instrument Panel Cutting Reply with quote
Steve did my new panel on my RV-4 as well...check out
www.mykitlog.com/pbesing Nice work, Steve.
Paul Besing
