Posted: Wed Nov 28, 2012 5:17 am Post subject: Fuel pump fittings with cooling shroud attached |
Folks,
I have the cooling shroud sold by Aircraft Spruce over my fuel pump. I thought I had the fittings tightened well - but still have a leak.
For those of you that have a similar configuration, how did you tighten the fittings? With all of the other stuff back there (prop governor) as well as the shroud covering the access it is very difficult to get a wrench in there. Is there a special tool - or did someone grind down something to make a special tool?
Ralph
RV6A N822AR IO360B1F6
panamared505(at)brier.net Guest
Posted: Wed Nov 28, 2012 12:45 pm Post subject: Fuel pump fittings with cooling shroud attached |
As I recall, it was an 1/8th turn by turn, and it took all afternoon. I may
have used some form a gasket type stuff as well.
However I did it, no leaks. I can't recall, but I think the bolts are
safety wired and that was the most difficult part.
RV-6
