woxofswa
Posted: Sat Dec 01, 2012 8:26 am Post subject: Mag cooling tubes |
I'll be running Bendix 1200's primarily in AZ. I'm curious about the brain trust consensus about mag cooling tubes. My spam cans never had them.
Is the air worth taking or is the air put to better use left in the containment area?
What about the fuel pump?
Thanks in advance.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
Posted: Sat Dec 01, 2012 10:28 am Post subject: Mag cooling tubes |
I think it helps to cool the part of the mag closest to the breaker cam. The little plastic follower that rides on the cam seems most sensitive to heat. Make sure you keep the tube up close the the magneto case so the cooler air doesn't get diluted before it reaches the mag.
I don't cool my fuel pump but I don't have to deal with the OATs that you do.
Dave Saylor
831-750-0284 CL
On Sat, Dec 1, 2012 at 8:26 AM, woxofswa <woxof(at)aol.com (woxof(at)aol.com)> wrote:
[quote] --> RV10-List message posted by: "woxofswa" <woxof(at)aol.com (woxof(at)aol.com)>
Are they air worth taking or is the air put to better use left in the containment area?
Thanks in advance.
Myron Nelson
Mesa, AZ
Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress.
http://forums.matronics.com/viewtopic.php?p=389673#389673
target="_blank">www.aeroelectric.com
ldersbooks.com" target="_blank">www.buildersbooks.com
" target="_blank">www.homebuilthelp.com
-Matt Dralle, List Admin.
" target="_blank">http://www.matronics.com/Navigator?RV10-List
MS -
Posted: Sat Dec 01, 2012 11:59 am Post subject: Mag cooling tubes |
I'm not using cooling tubes on the mags - I will however back fit a small
tube if/when Brad at Emag ever gets the six cylinder electronic ignition
done.
On the fuel pump, no cooling tube but I had a lot of concern on the location
of the cabin heat control valves. In the summertime all that really hot air
coming off the heat muffs is dumped right toward the fuel pump. I put a
piece of KoolMat
http://www.aircraftspruce.com/search/search.php?s=KOOLMAT+INSULATION&x=0&y=0
between the firewall and the control valves (hole cut out where the value
penetrates the firewall0 then draped the KoolMat over the top of the valves,
tucking the end between the bottom of the valves and the nose gear mount.
This redirects the dumped hot air down and away from the engine and fuel
pump.
Carl
robin(at)PaintTheWeb.com Guest
Posted: Sat Dec 01, 2012 12:10 pm Post subject: Mag cooling tubes |
Carl,
I suspect you will have built your RV-27 before the 6 cylinder P-Mag arrives.
Robin
Kellym
Posted: Sat Dec 01, 2012 4:34 pm Post subject: Mag cooling tubes |
I believe the Bendix 1200 uses a very different breaker cam follower
arrangement than the Slicks the new engines come with.
I don't know if there is anything in the Bendix that is particularly
heat sensitive, but my Mooney has cooling blast tubes for the stock
Bendix mags it came with 47 yrs ago.
On 12/1/2012 11:26 AM, Dave Saylor wrote:
Quote: | I think it helps to cool the part of the mag closest to the breaker
the mag.
you do.
Dave Saylor
831-750-0284 CL
never had them.
Thanks in advance.
Myron Nelson
Mesa, AZ
MS -
Checked by AVG - www.avg.com
KCHD |
