swacpt(at)hotmail.com Guest
Posted: Wed Dec 12, 2012 10:08 am Post subject: Z-13 Using PP Alternator |
I have the Plane Power 60 Amp alternator in my RV-7, which is about 95% complete. I do not have an electronics background, so I question as to whether or not I have wired my airplane correctly. I am using the AeroElectric Z-13 diagram, but the Plane Power 60 amp alternator has an internal regulator, and built in crowbar overvoltage protection. Therefore I have modified Z-13 to eliminate the external regulator. Can anyone tell me if my modified diagram looks correct ? If not, what needs to be changed to enable my electrical system to function correctly ? Any assistance is appreciated.
Thanks, Larry Elliott, N422LE
 Download |
| Filename: |
N422LE_ElecSystem.pdf |
584.28 KB |
| Downloaded: |
308 Time(s) |
email(at)jaredyates.com Guest
Posted: Wed Dec 12, 2012 10:40 am Post subject: Z-13 Using PP Alternator |
I did mine in a similar way with the red wire, but I didn't use the white wire. Are you sure that illumination of that bulb means low voltage? I was thinking it was a more general fault light. I used Bob's other little low voltage warning circuit for the crucial low voltage role.
On Wed, Dec 12, 2012 at 1:06 PM, Larry Elliott <swacpt(at)hotmail.com (swacpt(at)hotmail.com)> wrote:
[quote] I have the Plane Power 60 Amp alternator in my RV-7, which is about 95% complete. I do not have an electronics background, so I question as to whether or not I have wired my airplane correctly. I am using the AeroElectric Z-13 diagram, but the Plane Power 60 amp alternator has an internal regulator, and built in crowbar overvoltage protection. Therefore I have modified Z-13 to eliminate the external regulator. Can anyone tell me if my modified diagram looks correct ? If not, what needs to be changed to enable my electrical system to function correctly ? Any assistance is appreciated.
kuffel(at)cyberport.net Guest
Posted: Wed Dec 12, 2012 11:02 am Post subject: Z-13 Using PP Alternator |
Larry,
<< Can anyone tell me if my modified diagram looks correct ? If not, what needs to be changed to enable my electrical system to function correctly ? >>
Minor point. You are missing a power source for the main battery contactor. Connect point "I" to point "S" on your diagram.
Tom Kuffel
Posted: Wed Dec 12, 2012 12:12 pm Post subject: Z-13 Using PP Alternator |
At 12:39 PM 12/12/2012, you wrote:
| Quote: | I did mine in a similar way with the red wire, but I didn't use the
voltage role.
Good catch. I agree that incorporation of the PP product
into Z-13 is correct. I also suggest that the alternator
inop lite built into the PP product be suplimented if not
replaced by a dedicated active notification of low voltage.
Eric has some product. I'll have some product again soon.
If you're of a mind to roll your own, you could consider
http://tinyurl.com/6mvso29
How ever you achieve it, independent notification
of bus voltage below 13.0 volts is a really good
idea.
