jglazener
Joined: 14 Apr 2010 Posts: 76 Location: Schoonhoven, Netherlands
Posted: Mon Dec 17, 2012 1:51 pm Post subject: Door Lugs - serious problem |
I have nearly finished fitting my doors. Last weekend I put in the ball fittings for the gas struts. I put on the struts, and with a felt pen in hand to cross off yet another historic chapter I gently closed the door. Crack!!- the lug had not just broken off but practically disintegrated.
See http://www.europaowners.org/main.php?g2_itemId=105733
Shocked but assuming this was a one off I moved to the other door. Mindfully I treated this very carefully, but even with light hand pressure the lug also came off forthwith.
I understand from another builder that there should be an aluminium plate inside the lug, but there certainly are none in mine, at least not in the position of the hole.
Anybody had this same problem? If so is there a repair method?
_________________ Jeroen
http://www.europaowners.org/main.php?g2_itemId=44165 |
Rocketman
Posted: Mon Dec 17, 2012 2:11 pm Post subject: Door Lugs - serious problem |
As you were told, there should have been a thick piece of aluminum
inside that lug. That's the way mine is made and I've never had a
problem...
Jeff - Baby Blue
On 12/17/2012 3:51 PM, jglazener wrote:
Jeroen
http://forums.matronics.com/viewtopic.php?p=390616#390616
rlborger(at)mac.com Guest
Posted: Mon Dec 17, 2012 2:16 pm Post subject: Door Lugs - serious problem |
Hi Jeroen,
Been there, done that, got the T-shirt: http://www.europaowners.org/main.php?g2_itemId=64400
To see my fix, go to my build album, Year 6, Q1, 2007, page 4, starting with picture DSCN5547Ann and going to DSCN5558Ann
The fix has been working quite well since that time.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
Jeroen
max8992
Posted: Tue Dec 18, 2012 12:44 am Post subject: Door Lugs - serious problem |
Hi Jeroen,
Got the ship with the old style position of the gas struts. Changed them to
new style but didn't use the very expensive Mod66 and used thin pieces of
aluminum almost like Roger did.
Max Cointe
F-PMLH Europa_TriGear
Kit #560 912ULS Airmaster 450 hours
mcointe(at)free.fr
-----Message d'origine-----
De : owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com] De la part de Robert Borger
Envoyé : lundi 17 décembre 2012 23:16
À : europa-list(at)matronics.com
Objet : Re: Door Lugs - serious problem
Hi Jeroen,
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
Jeroen
_________________ Max8992
Europa XS #560 F-PMLH |
