handfordp(at)aol.com Guest
Posted: Fri Dec 07, 2012 8:33 am Post subject: Moving the tri-gear |
I have been wrestling with the problem of an effective way of a way to single handedly move the Europa around without using the prop. I would like to use a conventional type hitch to nose wheel that has a speed kit. If anyone has any bright ideas, please let me know, either direct on handfordp(at)aol.com or via the forum. Thank you, Peter.
Sent from my iPad
07936 374 452 (mobile)
rholder(at)avnet.co.uk Guest
Posted: Fri Dec 07, 2012 9:22 am Post subject: Moving the tri-gear |
On 07/12/2012 16:32, Peter Handford wrote:
| Quote: | I have been wrestling with the problem of an effective
What is wrong with using the prop ? When running it takes a
much greater load than you could apply by pulling !
Normally any nosewheel device is used for steering, not
for pulling !
Having said all that I have a lug on one side of the
nosewheel shaft, which protrudes through a hole in the
spat and to which I can connect a long handle with a
matching female for the lug. i use it only for steering
though !
Richard
G-OWWW
Europa TriGear
High Cross
budyerly(at)msn.com Guest
Posted: Fri Dec 14, 2012 3:51 pm Post subject: Moving the tri-gear |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Peter,
Check my towbar on my website: www.customflightcreations.com
Bud Yerly
