nickc(at)mtaonline.net Guest
Posted: Wed Dec 19, 2012 10:03 am Post subject: Question about Airframe lifespan...inspection ports? |
Hello Kolbers,
Your question is not “silly” Wesley!
The great thing about the Kolb list is that there are no “silly” questions; everyone on the list has a different background and bring a variety of experiences to the list. So ask away!
Two days ago, the North American distributor of Oratex fabric asked me what I was planning on coating my wings frames with before covering them?
My memory is that almost no one treats the aluminum with anything. I do have a recollection of the story of Kolb once coated a frame with Zinc chromate for a fellow who lived on the salt water of Chesapeake bay and intended to operate on floats.
My question for the list how many inspection ports do folks put in their wings?
Nick Cassara
Palmer, AK
607AK
Posted: Wed Dec 19, 2012 12:10 pm Post subject: Question about Airframe lifespan...inspection ports? |
Nick Cassara | Quote: | | Nick/Kolbers: I use epoxy chromate primer on all the 4130 parts and fuselage. Nothing on the aluminum unless I am going to finish paint, then apply epoxy chromate primer. Put as many inspection rings on your wings, or any other place for that matter, that you think you will "ever" need in the future. All you have to do is process the inspection rings during covering and painting. If and when you ever need to get inside, simply cut out the inside of the ring, then place the pre-painted inspection covers on them. john h | 012
_________________ John Hauck
Titus, Alabama |
beauford173(at)tampabay.r Guest
Posted: Wed Dec 19, 2012 5:34 pm Post subject: Question about Airframe lifespan...inspection ports? |
Brother Cassara:
Not sure what the majority of folks do, but I put one ring on each side of the spar at the strut attachment fitting, and one
at the root to look at the drag strut attachment to the wing butt rib. I open and use all three at each annual.
No reason I can see that a man could not put more on the wing if desired. Guess it depends on how pessimistic one
wants to be.
Worth what ye paid fer it…
Beauford
FF-076
N173BW
Brandon, FL
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Nick Cassara
Subject: Question about Airframe lifespan...inspection ports?
Nick Cassara
Palmer, AK
607AK
yellowbird1
Posted: Wed Dec 19, 2012 7:05 pm Post subject: Question about Airframe lifespan...inspection ports? |
I don't have a Kolb yet, so I don't quite understand how an inspection ring works. A picture is worth a thousand words.
Brad
On Dec 19, 2012, at 13:09, "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
[quote] 1024x768 <![endif]--> Clean false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 <![endif]--> <![endif]-->/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";} <![endif]--> <![endif]--> <![endif]-->
_________________ Brad Nation,
Albuquerque, NM
MK3 Xtra |
Posted: Wed Dec 19, 2012 7:57 pm Post subject: Question about Airframe lifespan...inspection ports? |
Brad
Brad/Kolbers:
The ring is a plastic reinforcement for the inspection hole covers. Keeps from tearing the fabric. Gives the cover springs something to hold on to keep them in place\.
Here's a bunch of questions and answers about inspection rings:
http://www.polyfiber.com/techquestions/inspectionrings/index.htm
Google this, "fabric aircraft inspection rings" and hit IMAGES. You'll get a lot of photos of rings and how they are used.
[quote] [b]
Titus, Alabama |
