Posted: Wed Jun 07, 2006 7:04 am Post subject: Landing Leg Replacement on a FireFly |
It is raining, so I put together a page. It can be seen at:
http://www.thirdshift.com/jack/firefly/firefly127.html
Jack B. Hart FF004
Winchester, IN
| Quote: | Jack B. Hart FF004
Winchester, IN
ulflyer(at)verizon.net Guest
Posted: Wed Jun 07, 2006 7:38 pm Post subject: Landing Leg Replacement on a FireFly |
Anyone know why a newer leg would be longer than older leg?
Could it be that the slight increase in length make the tail heavier
thus help reduce the FireFly's tenancy to nose over under the right
conditions. We had an early model FireFly and it would go over
pretty easy compared to the FireStars. Usually occurred when you
were slow and the only harm was the pilots embarrassment being stuck
with the nose on the ground and the tail up in the air. I know I had
asked/suggested they move the gear forward just a little or extend it
to help reduce this tendency - could they had incorporated it, if so
that is a good thing.
jerb
At 11:09 AM 6/7/2006, you wrote:
