				 Posted: Tue Dec 25, 2012 6:43 am    Post subject: Problem with the Harbor Freight Carbon   Pile  battery teste |
				All is well now.  Not exactly sure what my problem was but I suspect
 that 1) at some point I  had completely unscrewed the knob and 2) one of
 the carbon disk got out of position and got jammed.  But I can't be
 sure.  For those interested, I made some additional notes among those
 already made at the bottom of this note.
 So I proceeded on with the task I had in mind.
 I run a Z-14 with dual PC680s.  It seemed that one of my batteries is
 below par.  In cold weather 1 of my 3 GRT HX screens will not boot up
 before engine start and the alternator comes on line.  The plan has
 always been to keep the best battery on the starter circuit so I figured
 it may be time to get a new one and swap the starter battery to the GRT
 circuit.
 In addition, I get a solid warning light from the LRC3 regulator on that
 circuit.  I'm not sure that is a battery problem at all but hoping it
 may clear up too.
 Even though I've only been flying the RV10 for 1.5 years, I've been
 playing with PC680s for 6 or 7 years now.  With the latest purchase, I
 now have 5 batteries (!!).  I've hurt 1 or 2 of them by using them
 heavily and recharging them exclusively with a trickle charger before I
 learned better.  By the time the plane was flying, they wouldn't charge
 up to full capacity.
 But the task at hand was to test the performance of all 5 batteries to
 confirm selection of the best two.  Here is the test and the results.
 The battery numbers reflect the sequence of purchase.  (Temp = 62F)
                 Initial Voltage       Voltage 30min after load
 Battery        24hrs after charge    120amps for 15 sec
 Batt1            12.71                12.56
 Batt2            13.10                13.02
 Batt3            13.00                12.84
 Batt4            12.99                12.86
 Batt5            13.15                13.08
 I had been using Batts 2&3.  Now I will be moving 3 out of the plane,
 putting 2 in it's place and using Batt5 on the starter circuit.
 Interestingly, I would have come to same conclusions using the first
 column of numbers (without load testing) that I would have based on the
 load testing.
 Battery 4 is the 'aviation version' of the PC680.  Right out of the box,
 It never performed as well as the standard PC680s, even though there is
 no apparent external difference other than mention of "PMA" and it's all
 orange color.  In the end, it's never been in the plane.
 Thanks Bob and everyone!
 Bill Watson
 On 12/24/2012 10:09 AM, Robert L. Nuckolls, III wrote:
  <nuckolls.bob(at)aeroelectric.com>
  At 06:25 PM 12/23/2012, you wrote:
 > <Mauledriver(at)nc.rr.com>
 > I've used this unit a few times without a problem.  Then it suddenly
 > stopped working.  I couldn't seem to apply a load though the exact
 > symptoms I don't quite remember.
   is it failing to APPLY a load or failing to
   INDICATE what that load is? Does the voltmeter
   behave as expected?  Can you depress the voltmeter
   reading and get it to smell hot by cranking the
   load knob down?
 Voltmeter was working fine.  Cranking the knob resulted in no change, no
 smell.  I think the know was jammed by a disk being out of position.
 > Today, I pulled the unit apart and found
 > 1) a fuse on a small circuit board which had not blown (not easily
 > replaceable either)
 > 2) the carbon disks that presumably supplies the variable resistance
 > seem to be stacked between two steel plates  but the carbon disks
 > appeared to be loose or askew.
    Those are classically not tightly captive.
    A carbon pile rheostat is a PRESSURE device
    wherein once the slack is taken out of the
    stack height by the first turn of load knob
    rotation, the pile doesn't physically move
    much after that. It's behavior is a response
    to pressure not motion.
 That makes sense.
 > If I screw the big knob down and shake things a bit, I can get the
 > stack of carbon plates lined up and it seems that increased
 > resistance results from placing more pressure on the stack.
 > Does that sound right?
    No, the resistance between the fat wires to hte
    battery should drop markedly. To load a battery
    to 500A at 8 volts requires a resistance on
    the order of 16 MILLIOHMS.
 My mistake here - I was referring to physical resistance on the knob,
 not electrical resistance
 > Furthermore, it would seem for consistent operation, it would be best
 > to lie the unit on its back to insure the carbon plates remain flat.
     Doesn't matter.
 > Tomorrow I will attempt to use it again to see if it works now that
 > the plates are back in position.
 > Any insight or tips welcome.  I will report further tomorrow.
     I've got two of these critters and they've
     performed as expected for 5+ years. Sounds
     like something may be unhooked. Tell us what
     behaviors you see on the voltmeter while trying
     to get the load increased.
  Checked by AVG - www.avg.com
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
