Posted: Thu Dec 20, 2012 10:39 am Post subject: RF interference on GRT fuel pressure with PTT |
At 11:53 AM 12/20/2012, you wrote:
| Quote: | Hi Bob
This post from several weeks ago but Id like to revisit it please, I
plan to try to fix this problem soon.
Again the problem is fuel pressure indication spike on transmit from
either comm at the higher end of the band.
The engine monitor connector is a DB-25. My plan is to install the
capacitor listed between the fuel pressure "Aux" input and ground
pins inside the connector if possible using short-as-possible lead
length, then a split toroid on the wire bundle coming into the DB-25connector.
Thanks for any clarification, Tim
Try just the capacitor first. Add only one component
at a time to make sure that you know the benefit of
each. I've had readers report that a whole lot of
"stuff" in an RFI mitigation experiment was "successful"
leaving me wondering how much of that stuff could be
taken out without reducing the degree of success.
ChangDriver
Posted: Wed Dec 26, 2012 2:07 pm Post subject: Re: RF interference on GRT fuel pressure with PTT |
Forget about trying to put the capacitor on the line and solder to ground and just get one of these noise supression connector adapters.
http://www.camiresearch.com/connector_protector.html
Way simpler and it puts EMI supression on each pin!
