scott(at)s-f-x.com Guest
Posted: Fri Dec 28, 2012 6:29 am Post subject: Trim options |
Hi
Happy Xmas everyone.
Just hoping some of you guys might have trim tabs rather than the spring bias type pitch trim system - please let me know if the details for this build/mod are available as I found a nice linear actuator but the LAA (EAA UK equivalent) are starting to pick holes in the design. I need 60mm of travel so using Ray Allen servos directly is not feasible. If anyone has aileron trim without springs that would also be of interest.
Cheers
Scott MacIntyre
| | - The Matronics Pulsar-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
gregsmi
Posted: Fri Dec 28, 2012 8:56 am Post subject: Trim options |
Scott, Aerodesigns did not like trim servos because of the added weight to the control surface. They were very concerned about flutter.
Greg
In a message dated 12/28/2012 8:30:20 A.M. Central Standard Time, scott(at)s-f-x.com writes:
| Quote: | Hi
Cheers
Scott MacIntyre
lwheat2083(at)gmail.com Guest
Posted: Fri Dec 28, 2012 11:34 am Post subject: Trim options |
I have electric trims on my Pulsar III if you are interested. Have pics as well. Cheers, Larry N852LW
On Fri, Dec 28, 2012 at 6:29 AM, Scott MacIntyre <scott(at)s-f-x.com (scott(at)s-f-x.com)> wrote:
| Quote: | Hi
Cheers
Scott MacIntyre
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
="_blank">www.homebuilthelp.com
arget="_blank">http://www.matronics.com/Navigator?Pulsar-List
tp://forums.matronics.com
Larry Wheat [quote][b]
briana(at)xtra.co.nz Guest
Posted: Fri Dec 28, 2012 12:20 pm Post subject: Trim options |
Scott,
Scott
Trimming the position of the centre point of the pitch springs works just fine. Many of us use a lever arrangement with the servo connected at about the mid point of the lever, giving 2x the travel to the connection point of the springs.
Also the very light springs used on some of the aileron trim systems is not even noticeable, in terms of the stick force to deflect the ailerons in flight. My system has the servo connected to a small pulley, and via a cable to the spring on one side only. The 2x movement gain works out at exactly the right amount of trim change to compensate for passenger and fuel loads.
Brian
On 29/12/2012, at 3:29 AM, Scott MacIntyre <scott(at)s-f-x.com (scott(at)s-f-x.com)> wrote:
[quote]Hi
Cheers
Scott MacIntyre
href="http://www.aeroelectric.com/">www.aeroelectric.com
href="http://www.buildersbooks.com/">www.buildersbooks.com
href="http://www.homebuilthelp.com/">www.homebuilthelp.com
href="http://www.matronics.com/Navigator?Pulsar-List">http://www.matronics.com/Navigator?Pulsar-List
Posted: Fri Dec 28, 2012 2:38 pm Post subject: Trim options |
I used a linear actuator, very small with 144 in oz of force. Works very well. If you are interested I have picks and a supplier that I would be glad to forward to you. Cheers, Larry N852LW
| Quote: | Hi
Cheers
Scott MacIntyre
mjb777
Posted: Fri Dec 28, 2012 2:52 pm Post subject: Trim options |
Any chance you could post the details on the list larry?Thanks,Matt. Empower your Business with BlackBerry® and Mobile Solutions from Etisalat
Sender: owner-pulsar-list-server(at)matronics.com
Date: Fri, 28 Dec 2012 14:37:10 -0800
To: <pulsar-list(at)matronics.com>
ReplyTo: pulsar-list(at)matronics.com
Subject: Re: Pulsar-List: Trim options
I used a linear actuator, very small with 144 in oz of force. Works very we= ll. If you are interested I have picks and a supplier that I would be glad = to forward to you. Cheers, Larry N852LW
On Fri, Dec 28, 2012 at 6:29 AM, Scott MacIntyre <scott(at)s-f-x.com> wrote:
| Quote: | Hi
Happy Xmas everyo= ne.
Just hoping some of you guys might have trim t= abs rather than the spring bias type pitch trim system - please let me know= if the details for this build/mod are available as I found a nice linear a= ctuator but the LAA (EAA UK equivalent) are starting to pick holes in the d= esign. I need 60mm of travel so using Ray Allen servos directly is not feas= ible. If anyone has aileron trim without springs that would also be of inte= rest.
Cheers
Scott MacIntyre
.com" target=3D"_blank">www.buildersbooks.com
=3D"_blank">www.homebuilthelp.com
arget=3D"_blank">http://www.matronics.com/Navigator?Pulsar-List
</= div>--
_________________ Pulsar 1 TD Kit.
Captain B777.
Licenced Aircraft Maintenance Engineer. |
Posted: Fri Dec 28, 2012 3:02 pm Post subject: Trim options |
I will try I am haaving nothing but problems with Windows 8, really sucks. Cheers
On Fri, Dec 28, 2012 at 2:50 PM, <mattbrock777(at)gmail.com (mattbrock777(at)gmail.com)> wrote:
| Quote: | Any chance you could post the details on the list larry?
Matt.
From: Larry Wheat <lwheat2083(at)gmail.com (lwheat2083(at)gmail.com)>
Sender: owner-pulsar-list-server(at)matronics.com (owner-pulsar-list-server(at)matronics.com)
To: <pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)>
ReplyTo: pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Subject: Re: Trim options
| Quote: | Hi
Cheers
Scott MacIntyre
Larry Wheat | Quote: |
mjb777
Posted: Fri Dec 28, 2012 3:09 pm Post subject: Trim options |
I ditched it when I bought a new laptop recently. Went back to 7.
Good luck!!
Matt.
Captain B777.
MyronTruex(at)comcast.net Guest
Posted: Sat Dec 29, 2012 9:25 am Post subject: Trim options |
If I needed to build another trim kit I would use the mac servo switches on the stick again and my own actuators. The Macs have small travel distances and are not very powerful. I used a linear actuator on my 40 foot motorhome to provide center trimming for crosswinds and road conditions. Works great.
http://dcactuators.com/Detail.asp?Product_ID=302.130_6104T
Myron
30TX
From: owner-pulsar-list-server(at)matronics.com [mailto:owner-pulsar-list-server(at)matronics.com] On Behalf Of Brian Anderson
Sent: Friday, December 28, 2012 12:20 PM
Scott,
Scott
Brian
Hi
Cheers
Scott MacIntyre
| Quote: | | href="http://www.aeroelectric.com/">www.aeroelectric.comhref="http://www.buildersbooks.com/">www.buildersbooks.comhref="http://www.homebuilthelp.com/">www.homebuilthelp.comhref="http://www.matronics.com/contribution">http://www.matronics.com/contributionhref="http://www.matronics.com/Navigator?Pulsar-List">http://www.matronics.com/Navigator?Pulsar-Listhref="http://forums.matronics.com/">http://forums.matronics.com |
0123456789 | Quote: | | href="http://www.aeroelectric.com/">www.aeroelectric.com | 0 | Quote: | | href="http://www.aeroelectric.com/">www.aeroelectric.com | 1 | Quote: | | href="http://www.aeroelectric.com/">www.aeroelectric.com | 2 | Quote: | | href="http://www.aeroelectric.com/">www.aeroelectric.com | 3 | Quote: | | href="http://www.aeroelectric.com/">www.aeroelectric.com | 4 | Quote: | | href="http://www.aeroelectric.com/">www.aeroelectric.com | 5 | Quote: | | href="http://www.aeroelectric.com/">www.aeroelectric.com | 6 | Quote: | | href="http://www.aeroelectric.com/">www.aeroelectric.com | 7 | Quote: | | href="http://www.aeroelectric.com/">www.aeroelectric.com | 8 | Quote: | | href="http://www.aeroelectric.com/">www.aeroelectric.com | 9 | Quote: | | href="http://www.buildersbooks.com/">www.buildersbooks.com | 0 | Quote: | | href="http://www.buildersbooks.com/">www.buildersbooks.com | 1 | Quote: | | href="http://www.buildersbooks.com/">www.buildersbooks.com | 2 | Quote: | | href="http://www.buildersbooks.com/">www.buildersbooks.com | 3 | Quote: | | href="http://www.buildersbooks.com/">www.buildersbooks.com | 4 | Quote: | | href="http://www.buildersbooks.com/">www.buildersbooks.com | 5 | Quote: | | href="http://www.buildersbooks.com/">www.buildersbooks.com | 6 | Quote: | | href="http://www.buildersbooks.com/">www.buildersbooks.com | 7 | Quote: | | href="http://www.buildersbooks.com/">www.buildersbooks.com | 8
