Tim Olson
Posted: Wed Jan 02, 2013 8:40 am Post subject: Proseal cartridges |
Looking at doing a set of tanks, last time I just used
quarts of proseal. I'm considering just doing that again,
as it looks like the cheapest way to go. I know that
there were semco guns and cartridges for proseal though.
Van's shows them and they're only 3.5 oz kits.
Is there something in between that I'm missing?
I mean, if I want to get like 1.5 quarts worth, is there
any *affordable* way to do this with cartridges so that
I don't have the mix and mess....or should I just tough
it out and do the old ziploc bag squeezer thing again?
I hate proseal...as does everyone, but I'm glad to build
my own tanks so I know they were built leak-free with
plenty of goo.
Tim
charliewaffles
Posted: Wed Jan 02, 2013 8:59 am Post subject: Re: Proseal cartridges |
You could do a hybrid solution. Those SEM catridges can be re-used. So you could get two of the cartridges and a quart of proseal. When the cartridge is used up, you pull the plunger and wait for it to cure, pull the proseal out and refill from the quart container.
Bajajim
Posted: Wed Jan 02, 2013 9:09 am Post subject: Proseal cartridges |
You could also go to Home Depot, Buy a $2 tube of latex calk, empty the
cartridge and use it...
Works GREAT!!!
jeff(at)westcottpress.com Guest
Hi Tim,
I mixed small batches with tongue depressors on paper cards... then spread it on the flanges with the tongue depressors... could almost pull it off without gloves.
Jeff Carpenter
40304
On Jan 2, 2013, at 8:39 AM, Tim Olson wrote:
plenty of goo.
Tim
rv10pro(at)gmail.com Guest
Posted: Wed Jan 02, 2013 9:32 am Post subject: Proseal cartridges |
Your killing me Tim. By now you should know we blow through more than a dozen cartridges a day at work.
Just let me know how many you want. I demo using a HF air tip with rubber boot to reverse blow the cured empty cartridge apart. The thermoplastic is re- usable. I also have different new tips for various reaches.
Allows batches to be mixed in buckets or cups and then loaded for use into pre-used cartridges. Let me know if you don't have access to a pneumatic pro seal gun. Will loan whatever you need as late birthday present. Keeping you cost low is payback for all that you have done for the RV-10 family.
The baggies went the way of H-5606 back in the dark ages of building those first RV-10's
OK I knew there would someday be an advantage of getting old and taking a decade on builds.
John 40600 On Jan 2, 2013 8:44 AM, "Tim Olson" <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:[quote] --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
plenty of goo.
Tim
om" target="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
http://forums.matronics.com
Tim Olson
Posted: Wed Jan 02, 2013 9:33 am Post subject: Proseal cartridges |
On 1/2/2013 11:08 AM, JimVillani wrote:
Works GREAT!!!
You know, after seeing the reply on the empty tubes, I was
thinking that same thing to myself....."why can't I just buy
a nice plastic tube of caulk and do the same dang thing".
That's a great idea.
Sold!
Tim
Tim Olson
Posted: Wed Jan 02, 2013 9:36 am Post subject: Proseal cartridges |
That's pretty much what I did the first time. Mixed it on
paper plates and use tongue depressors. I found that
loading a flexible ziploc bag was tough...the bag was
too flimsy. But, the caulk tube, now THAT would be easier
to load. The plate thing will work too, as a backup, because
that's how I'll mix it to load the tubes. So I think that's
a winning combination....and of course, once I have the ribs
in place, I'll use the tongue depressors to get the top sides
of the rivets too.
Very good, thanks guys.
PS: The RV14 is so very similar in starting the wings to
the RV-10...it's amazing. I started to scratch my head
a couple times and then looked at my RV-10 website photos
and it was instantly clear. I can't believe it's been
almost 7 years since I first flew, and that puts it
at nearly 9 years since I built wings. Time sure funs
when you're having flytime!
Tim
On 1/2/2013 11:09 AM, Jeff Carpenter wrote:
Hi Tim,
Jeff Carpenter
40304
> plenty of goo.
> Tim
> do not archive
seipel(at)seznam.cz Guest
Posted: Wed Jan 02, 2013 9:49 am Post subject: Proseal cartridges |
Tim,
I bought a used semco gun on ebay for $30, and the empty cartridges from
Aircraft Spruce (although they seem to be available on ebay as well,
maybe cheaper) and filled them myself from the quart kit. Not as cheap
as using a ziplock bag, but much more controllable and way less messy in
my opinion. Overall costs less than using the pre-filled cartridges,
but you still have to mix and then shove the goo into the cartridge.
I've also used the semco gun/cartridges for applying epoxy/micro, etc so
I feel like it was a worthwhile purchase.
If you go with that route, be advised that you need the empty cartridge,
the nozzle, and the plunger which are sold separately and altogether
cost about $2.60 a set from ACS.
PJ Seipel
RV-10 #40032 - I'll finish someday..
On 1/2/2013 08:39, Tim Olson wrote:
plenty of goo.
Tim
rv10flyer(at)live.com Guest
I used Q-tips, took the cotton off and used the sticks to work around the
rivets. My thought was to use as little proseal without missing a pin hole.
The other option is the wooden coffee stirrer found at supermarkets.
The caulk tube option is another way. put the end-tip over the rivet (put
the tip into the rivet until it is flush with the skin) and by default the
proseal will cover the area than use a smaller piece as above to smooth it
around the rivets- if needed.
7 years.. gee whiz you aren't kidding! I can't believe it has been that long
either.
Pascal
rleffler
Posted: Wed Jan 02, 2013 10:09 am Post subject: Re: Proseal cartridges |
I bought empty cartridges to fill. I found it much easier just to mix on a paper plate and use a tongue depressor to apply, that to go through the fuss of filling the tube. It also cut down on your working time, but then it took me awhile to get the tube filled.
You can buy empty cartridges from the local supply shops. They're pretty inexpensive.
I do know somebody that has one of the large cartridges from Van's with I believe a 3/13 expiration that I'm sure he'll make a deal if somebody wanted it. Email me for the contact information if interested.
bob
_________________ Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler |
Lenny Iszak
Ron B.
Posted: Fri Jan 04, 2013 4:05 pm Post subject: Re: Proseal cartridges |
By utilizing used caulk tubes, are we not concerned about contamination and what it might do to proseal cure?
Bajajim
Posted: Sat Jan 05, 2013 1:43 pm Post subject: Proseal cartridges |
Latex Calk,
Soap and water clean up...
