aox1969(at)earthlink.net Guest
Posted: Tue Jan 08, 2013 1:25 pm Post subject: Jabiru 3300 Ideal Oil Temp |
Gentlemen,
This is my first winter with a Jabiru J-230 (with a Jabiru 3300 engine); and, I'd like your thoughts on the ideal Oil Temp, and the methods that you use to increase the Oil Temp.
My cruise (2800-2900 RPMs) Oil Temp was 140 F with an OAT of 30 F.
Since I was under the impression that the Oil Temp should be at least 180 F, to boil off the impurities; I covered the Oil Cooler Inlet to attempt to raise the Oil Temp.
With 1/3 of the Oil Cooler covered the Oil Temp increased to 152 F.
Next, I covered 2/3s of the Oil Cooler and that increased the Oil Temp to 163 F.
Then, I covered All of the Oil Cooler and that increased the Oil Temp to 174 F (it did get to 186 F in a 90 kt climb).
Please help me with your thoughts on this issue.
Thank you
OldNavy w/a Jab
plus2s
Posted: Wed Jan 09, 2013 2:01 am Post subject: Jabiru 3300 Ideal Oil Temp |
Are you using a multi grade oil ??
To: JabiruEngine-List Digest Server <jabiruengine-list(at)matronics.com>
Sent: Wednesday, 9 January 2013 10:24 AM
Subject: Jabiru 3300 Ideal Oil Temp
--> JabiruEngine-List message posted by: mdaniels <aox1969(at)earthlink.net (aox1969(at)earthlink.net)>
Gentlemen,
Thank you
OldNavy w/a Jab
_-========================;
drdoright(at)gowisper.net Guest
Posted: Thu Jan 10, 2013 6:58 am Post subject: Jabiru 3300 Ideal Oil Temp |
If your oil temperature sender is in the pan, like my 2200, then you can be sure that as the oil goes thru the heads it is getting hot enough to boil off moisture. Just be sure you warm it up some and turn the prop by hand before starting.
