Stall speed / GPS
Ralph Hoover
PostPosted: Fri Jan 13, 2006 10:56 am    Post subject: Stall speed / GPS Reply with quote
Dag-nab-it. I responded to an individual from my e-mail and thought I was responding to the BBS! Oh well. Some of you will have some fun with this. It combines my stall speed problem and responses with some information regarding GPS's.
"HEY MATT!!! Do we still use the do not archive or not"!
with that said here is what I responded to George E. Thompson.
Great idea George and others. And back at the last (second flight) I set my Garmin e-map into the firestar before my instructor moved the plane from my old airport to his field. With a program called mapsource and a cable to connect the GPS to the computer, I was able to download the information and view it as a doc and on the map program (Roads and Recreation). I have enclosed a copy of the doc file for your and others viewing pleasure / evaluation.
Also with the mapsource program I can see graphically, though I can’t seem to capture and download to a file for others to read or see the altitude for every crumb. I also through the program can see every move he made with the plane, two circles and several straight paths. He indicated that he did two stalls. With the documentation provided you in the 110.doc, can you find them?
I really appreciate this web site, especially on rainy cold days. Thanks guys.
Ralph “the other Ralph” Hoover…..(verses the Good Ralph on this site).
John Jung
PostPosted: Fri Jan 13, 2006 12:19 pm    Post subject: Re: Stall speed / GPS Reply with quote
Ralph,
Interesting file to look at, but without knowing the winds, I don't think it really tells you anything.
Here is how I check my airspeed: First, I pick a day without much wind. Then, I try to determine which way the wind is going by watching for drift and comparing the GPS with the airspeed. When I think I am going straight into the wind, I fly a a chosen airspeed and make note of the GPS. Then I turn around 180 degrees, hold the same speed, and get the GPS reading. If I average the GPS readings, I should have a true airspeed. This process can be repeated to give a more accurate average. It also can be done for different airspeeds. As long as the wind is steady and reading are taken while flying nearly into the wind and 180 degrees downwind, the results sould be decent. Flying in any other direction and trying to average will introduce an error.
To check for accuracy at stall speed, I do the above check at 5 over and assume that the difference is the same. My Firestar stalls at 38 or 39 when not in ground effect, 40 indicated, and 3 to 4 mph slower in ground effect.
I never count on ground effect. I never really noticed it when I landed it on short grass strips, but I do when I ease it onto a paved runway.
John Jung
Firestar II N6163J
Surprise, AZ
pj.ladd(at)btinternet.com
PostPosted: Sat Jan 14, 2006 2:35 am    Post subject: Stall speed / GPS Reply with quote
My Firestar stalls at 38 or 39 when not in ground effect>>
Hi All,
I am a bit surprised that anyone knows the stalling speed when low enough
to be in ground effect. I don`t think I have ever looked at the ASI after
coming `over the hedge` and certainly not after the round out.
Surely at that part of the landing you should be looking at `the picture`
through the windscreen, keeping wings level and `feeling` for the ground,
not looking at instruments.
Cheers
Pat
jbhart(at)onlyinternet.ne
PostPosted: Sat Jan 14, 2006 6:24 am    Post subject: Stall speed / GPS Reply with quote
Hi All,
Cheers
Pat
Pat,
The easiest and may be the safest way to determine ground effect stall speed
is to tease the plane off the ground in the three point stance. Pick a no
wind day and use a hard surface runway and inflate the tires to the max limit
to minimize the rolling resistance. For the FireFly to lift off in the
three point stance, I apply about 5 degrees flaperon and I hold the stick
back against the stop. By very slowly advancing the throttle, you can get
it to float off at minimum air speed. If the runway is long enough you can
back off the throttle and repeat the process several times.
This is the method, I used to determine wing vortex generator placement
effect on the FireFly. With a little practice you can become very good at
flying at minimum speed a foot or so above the runway while keeping an eye
on the ASI.
Jack B. Hart FF004
Winchester, IN
kinnepix(at)earthlink.net
PostPosted: Sat Jan 14, 2006 7:00 am    Post subject: Stall speed / GPS Reply with quote
Pat
That's what that cute sexy little blonde passenger is for! Let her do
the looking --
Russ
do not achive
Hi All,
enough
ASI after
picture`
ground,
Cheers
Pat
JetPilot
PostPosted: Sat Jan 14, 2006 8:04 am    Post subject: Re: Stall speed / GPS Reply with quote
kinnepix(at)earthlink.net wrote:
Pat
the looking --
Russ
My thoughts exactly, you beat me to it Very Happy
Kolb MK-III Xtra, 912-S
John Jung
PostPosted: Sat Jan 14, 2006 8:51 pm    Post subject: Re: Stall speed / GPS Reply with quote
Pat,
After 10 years of flying Firestars, I can fly a few feet over the runway, watch the airspeed, and fly by feel, without having to stare at the runway. It is a lot like keeping a car in the lane on the highway while watching the scenery, never staring at the road. It is a really good feeling to have a plane that feels like it is an extension on me.
John Jung
Firestar II N6163J
Surprise, AZ
ul15rhb(at)juno.com
PostPosted: Sun Jan 15, 2006 8:41 am    Post subject: Stall speed / GPS Reply with quote
Here in Minnesota we fly our Firestars inches above the frozen lakes. We fly for miles in ground effect only occasionally looking at the airspeed indicator. We are flying by feel and if we stall, the plane lands.
This is what we do here in the frozen northland.
Time to move back up here John J Smile
Ralph
Original Firestar
19 years flying it
-- "John Jung" <jrjungjr(at)yahoo.com> wrote:
Pat,
John Jung
Firestar II N6163J
Surprise, AZ
http://forums.matronics.com/viewtopic.php?p=4072#4072
Try Juno Platinum for Free! Then, only $9.95/month!
PostPosted: Sun Jan 15, 2006 12:39 pm    Post subject: Stall speed / GPS Reply with quote
is to tease the plane off the ground in the three point stance.>>
Hi,
I am sure you are right. When I leave the ground my object (usually) is to
get as far from it as quickly as possible. Bad things don `t happen when
you are flying. Its when you touch the hard stuff that all the nasties
start.
I saw a TV thing last night and one of the characters said "You shouldn`t be
afraid of flying. Its crashing you should be afraid of``. That about sums it
up.
Low flying should be done with bags of speed not messing about around the
stall.
A couple of good pictures exist. One is a Sunderland flying boat (its a big
plane, 4 engines and 2 decks) flying down the runway at Phenurpai (Sp) in
New Zealand with dust and bits of plane flying into the air. The other is a
painting which depicts a Boston or a Havoc during the first raid which the
Americans made on the Continent (I think they borrowed the planes from the
RAF) to celebrate the anniversary of the Yanks arrival in the UK. One hit
the runway, it was supposed to be low level, but bounced back into the air
and made it home.
In my book, unless you are landing, low level and low speed are not
comfortable bed mates.
Cheers
Pat
PostPosted: Sun Jan 15, 2006 12:42 pm    Post subject: Stall speed / GPS Reply with quote
That's what that cute sexy little blonde passenger is for! >>
Hi Russ,
you wouldn`t trust a blonde to give you the right time of day, let alone
your airspeed,
Pat
