Tdawson(at)avidyne.com Guest
Posted: Fri Jun 09, 2006 10:58 am Post subject: finishing kit omissions |
583! Good lord!
TDT
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Eric Ekberg
Sent: Friday, June 09, 2006 2:29 PM
Subject: Re: finishing kit ommisions
Is that a 300hp engine? Is that fuel injected? Can you use that cowling with fuel injection? Are you concerned with exceeding Van's Vne at altitude? Sorry for all the questions, just trying to learn.
Eric Ekberg
RV-10 583 - Empennage
On 6/9/06, RV Builder (Michael Sausen) <rvbuilder(at)sausen.net (rvbuilder(at)sausen.net)> wrote:
Here is the IO-540 & Finish kit contents. I don't have the stuff crossed out but it is basically what Chris listed below. I plan on putting together a list of exclusion items based on my engine config once I get to that point. My engine is the BPA IO-540-X with the cold air induction. I will be using the special James cowl (for the cold air induction) and also their plenum.
Michael Sausen
RV-10 #352 Working on Fuselage
Recent RV-10 Build Activity
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Tim Dawson-Townsend
Sent: Friday, June 09, 2006 11:16 AM
Subject: RE: finishing kit ommisions
I bet if you scan the list, Tim O will be happy to post it on his website . . .
TDT
40025
FF
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Chris Hukill
Sent: Friday, June 09, 2006 11:58 AM
Subject: finishing kit ommisions
I just sent Barb at Vans a list of the items to omit from my finishing kit. I previously had her send me an inventory list of the kit, so I knew what was there. As I want to leave my options open for a James cowl, I omitted the cowl top, bottom, left/ right inlets, oil door and core, and all the spinner parts (7 items). I also omitted the tires and tubes, as I like the leakguard tubes and better tires. If anyone wants the actual part numbers of the cowl / spinner parts to omit, I would be happy to fax the list, and save you and Vans the trouble.
Chris Hukill
completing Andair installation
702 591-7551 cel
