barrynorman(at)comcast.ne Guest
Posted: Thu Jan 17, 2013 3:04 pm Post subject: Water temps |
I noticed the last time I flew the plane in cold weather that the heat was a little on the weak side and water temps were only 135 degrees after leaving the engine. This was with 22 degree F OAT. I was considering stuffing a piece of foam in one of the wing root openings to block the air flow to one of the radiators to bring the temps up in the plane. Right now the hot coolant flows through a heater core in the cabin before it goes to the two wing roots. Cylinder head temps are in the 170 degree range. Has anyone else done this?
Barry
esalehto(at)yahoo.com Guest
Posted: Thu Jan 17, 2013 4:31 pm Post subject: Water temps |
Hi,
I asked same question from Yahoo group a week ago but haven't got any feedback. Can't be that we are the first ones facing cold cockpits! I have Pulsar XP and I think that I need to cover some part of the radiator.
Esa
Pulsar XP
Rotax 912
From: "barrynorman(at)comcast.net" <barrynorman(at)comcast.net>
To: pulsar-list <pulsar-list(at)matronics.com>
Sent: Thursday, January 17, 2013 3:03 PM
Subject: Pulsar-List: Water temps
#yiv1799691380 p {margin:0;}I noticed the last time I flew the plane in cold weather that the heat was a little on the weak side and water temps were only 135 degrees after leaving the engine. This was with 22 degree F OAT. I was considering stuffing a piece of foam in one of the wing root openings to block the air flow to one of the radiators to bring the temps up in the plane. Right now the hot coolant flows through a heater core in the cabin before it goes to the two wing roots. Cylinder head temps are in the 170 degree range. Has anyone else done this?
Barry
barryjedwards(at)lineone. Guest
Posted: Fri Jan 18, 2013 4:32 am Post subject: Water temps |
I block off part of my XP Series 1 radiators every year as it gets cold. On the Series one the oil rad is mounted in front of the coolant rad. I put a piece of rigid plastic between the two covering up to 1/3 of the main rad and most of the oil rad. It’s crude but it works well enough. Not that I have flown for months now. Our grass airstrip has been waterlogged for several months and I have a couple of mis-firing cylinders to sort. I know the problem and it’s simple to fix, I just cant be bothered to go and do it in the cold wet weather when I know I cant fly!
Barry
G-XPXP 912 Taildragger UK 1050hrs
From: barrynorman(at)comcast.net (barrynorman(at)comcast.net)
Sent: Thursday, January 17, 2013 11:03 PM
To: pulsar-list (pulsar-list(at)matronics.com)
Subject: Water temps
Barry
