Charles Heathco
Posted: Thu Jun 15, 2006 3:22 am Post subject: accessing Nav antena RV6a |
I found out that my nav antena under the tail end of fusl is on the fritz, balun conn is suspect. I didnt build the plane so assume it was mounted durring build. How to access it? Can one crawl back far enough to reach it? or cut an access hole? (if so is that a good idea as the place would be put over the hole without indentations like other acess hole have) Charlie Heathco
Posted: Thu Jun 15, 2006 4:32 am Post subject: accessing Nav antena RV6a |
Might be able to get to it from the top through where the HS is attached - depending on how far back it is.
I can get back there (5'9"(at)190) - but put something under the tail as it may fall while you're back there.
I have seen a number of -A's with it down there...it'll poke your shin not your eye under normal conditions....I have mine at the top of the VS and built the VS specifically that way.
[quote]--
ronlee(at)pcisys.net Guest
Posted: Thu Jun 15, 2006 4:41 am Post subject: accessing Nav antena RV6a |
At 05:20 AM 6/15/2006, you wrote:
| Quote: | | I found out that my nav antena under the tail end of fusl is on the fritz, balun conn is suspect. I didnt build the plane so assume it was mounted durring build. How to access it? Can one crawl back far enough to reach it? or cut an access hole? (if so is that a good idea as the place would be put over the hole without indentations like other acess hole have) Charlie Heathco |
Either access from the left side panel, remove the empennage fairing or crawl back (last option).
Support tail if you do the last and I used plywood as a floor to crawl back.
Ron Lee
mstewart(at)iss.net Guest
Posted: Thu Jun 15, 2006 5:06 am Post subject: accessing Nav antena RV6a |
Hey Charlie,
You should be able to reach through the bulkhead to retrieve it.
May take 2 people, one reaching through the top, one underneath turning screws.
You could send a young whipper snapper down the fuse inside if all else failsJ
Have you removed the fairing and tried to reach down in there?
Best,
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charles Heathco
Sent: Thursday, June 15, 2006 7:20 AM
To: rv-list(at)matronics.com
Subject: accessing Nav antena RV6a
bertrv6(at)highstream.net Guest
Posted: Thu Jun 15, 2006 6:33 am Post subject: accessing Nav antena RV6a |
Quoting Ron Lee <ronlee(at)pcisys.net>:
>Charlie Heathco
Ron Lee
Ron: you should be able to see it, thru the lighting holes on top of
fuselage once you removes the rudder, and cover etc..the holes are big enough
to put hand thru, to reach if necessary.
If you haves the side small panel, you can look also, and see where is connec-
ted.
I did, make another a little larger window on the other side fuselage,
it really only for inspection, little to do for working inside.
I did not wanted to cut thru the longerons....
Hope it will give you another idea
Bert
rv6a
Flying now
pbesing(at)yahoo.com Guest
Posted: Thu Jun 15, 2006 7:34 am Post subject: accessing Nav antena RV6a |
Crawling back there shouldn't be a big deal. I just
installed a nav antenna on the belly of my RV-4. I
took out the elevator pushrod, supported the tail, and
made it back there without too much difficulty...I'm
5'10 and 180 lbs.
Paul Besing
--- bertrv6(at)highstream.net wrote:
> >Charlie Heathco
> Ron Lee
> Do not archive
ted.
working inside.
Bert
rv6a
Flying now
browse
Subscriptions page,
FAQ,
Admin.
ghinman(at)mts.net Guest
Posted: Fri Jun 16, 2006 8:42 am Post subject: accessing Nav antena RV6a |
I have an RV-8 ,and use the following method to
crawl into the tail cone.
Place several pillows on bottom of the tail cone
between the bulkheads
Place long piece/pieces of plywood on top of pillows
Crawl on top of plywood.
I weigh about 160lbs,so if you weigh a lot more
get someone smaller to do it.
George H. Inman
ghinman(at)mts.net
Home 204 287 8334
Cell 204 799 7062
jhstarn(at)verizon.net Guest
Posted: Fri Jun 16, 2006 9:52 am Post subject: accessing Nav antena RV6a |
It's been a while back (7-8 years ago) but when doing the tail cone on HRII
N561FS we took a 5' piece of 3/8" plywood and cut it to fit. It looked like
a thin surfboard with notches cut in the sides to match the bulk heads. It
was cut so the surfboard rested only on the flat areas of the bulk heads.We
has several couch pillows that we placed between each of the bulkheads. We
made the "surfboard" before putting the top skin in place. I weight in at
240# but had the looong arms required to reach the far end. Ran the light
cord out thru the rear inspection hole (tube type to reduce heat) & put a
fan between my feet. We have reused it several times, rotate it to install
or remove. On HRII we would have to pull the elevator tube to use it now.
Things I would have done different: Sand & paint (white) the surf board,
especially the edges. Lots of splinters when sliding in and/or out. KABONG
