roger(at)trevannan.wanado Guest
Posted: Tue Jan 22, 2013 2:28 pm Post subject: Fusalage fuel stains |
Hi
I have a problem I believe is not uncommon ".After flight I find a stain along the rear fuselage caused by fuel venting from the vent on top of the fuselage. I have a fuel injected (not a Rotax ) classic mono with no sight gauge . I have one pipe from the tank to a vent on top the plane as per drawings. The return pipe for the pumps goes back to the port side of the tank. I am getting surges out of the breather pipe, I assumed this was just a drop of fuel in the breather pipe. I placed in the breather line, at the highest point a plastic fuel filter to hopefully stop a small surge. It does not work I am still getting fuel down the rear of the plane. Is this just over filling or am I missing something? Sorry if this has been addressed before but I don’t read every mail
Roger [quote][b]
Roland
Posted: Tue Jan 22, 2013 11:50 pm Post subject: Re: Fusalage fuel stains |
Hi Roger,
I refuel after each flight absolutely to the top until fuel spits out of the breather and I see it in the tank, since I don't have a reliable fuel gauge. I then trailer my Europa home and to the airport for the next flight. No fuel comes out. So I cannot imagine, that you just overfilled.
Hope this helps for troubleshooting.
Roland
PH-ZTI
XS Trigear 914
Alan Carter
Joined: 02 Jul 2012 Posts: 378 Location: Kent, England.
Posted: Wed Jan 23, 2013 1:36 am Post subject: Re: Fusalage fuel stains |
Hi Roland.
Just my thoughts, i don,t think its a good idea to fill to the top every time as you have fuel up large hoses which are in the cockpit so don,t think its a good ides to leave fuel there , it may be OK as fuel is in the rest of the rubber lines, but i would,nt.
My fuel gauge is useless 56 =35 lts, and i was flying around thinking all was well , So for the time being why not drain the tank, and refill by 5 lts at a time, and making a fuel chart, its a morning work but easy to do. Mine works well have tested know it pretty accurate so feel much happier now.
One day i will get round to recalibrating the gauge or a new one.
Alan
Roland
Posted: Wed Jan 23, 2013 2:14 am Post subject: Re: Fusalage fuel stains |
Good morning Alan,
as you suspected not ideal indeed. Until I have something better (on my to do list already), I feel best to know the total fuel quantity and calculate conservative with 20 l/h and still have the reserve to my disposal.
Roland
max8992
Posted: Wed Jan 23, 2013 2:47 am Post subject: Fusalage fuel stains |
Hi there all!
That has been addressed in a previous topic: fuel flow is the solution!
The Mod quoted is the LAA Mod 12209. (In the document some builders had said
which was that they had obtained adequate results by assuming the return
flow was constant and “fixing” the “K” factor accordingly)...
Max Cointe
mcointe(at)free.fr
F-PMLH Europa XS_TriGear
Kit #560-2003 912ULS/AirmasterAP332 450 hours
F-PLDJ Dyn’Aéro MCR 4S
Kit #27-2002 912ULSFR/MTProp MTV7A 1550 heures
-----Message d'origine-----
De : owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com] De la part de Roland
Envoyé : mercredi 23 janvier 2013 11:15
À : europa-list(at)matronics.com
Objet : Re: Fusalage fuel stains
Good morning Alan,
Roland
http://forums.matronics.com/viewtopic.php?p=392926#392926
_________________ Max8992
Europa XS #560 F-PMLH |
stephen vestuti
Posted: Wed Jan 23, 2013 3:22 am Post subject: Re: Fusalage fuel stains |
Hi Roger,
I had the same problem with my Europa - brown fuel stains from the roof fuel tank vent all the way to the tail plane, this happens with full fuel to the
filler cap on the climb out.
The solution is to cut the fuel vent line where it passes the top of the filler neck.
then, using AN fittings, connect the roof vent to the rear face at the top of the filler neck, and the tank vent to the Fwd. face at the top of the filler neck.
Steve.
houlihan(at)blueyonder.co Guest
Posted: Wed Jan 23, 2013 3:32 am Post subject: Fusalage fuel stains |
Hi Steve.Just for information , is your Europa a classic or an XS with the filler on the side ?
I have a similar problem with my Classic
Tim H
G-BZTH
On 23 January 2013 11:22, stephen vestuti <s.vestuti(at)gmail.com (s.vestuti(at)gmail.com)> wrote:
[quote]--> Europa-List message posted by: "stephen vestuti" <s.vestuti(at)gmail.com (s.vestuti(at)gmail.com)>
Hi Roger,
Steve.
stephen vestuti
Posted: Wed Jan 23, 2013 9:12 am Post subject: Re: Fusalage fuel stains |
Hi Tim,
Mine was an XS, It did it from day 1.
Forgot to mention you need to Redux the AN fittings to the filler neck as you screw then in.
Steve.
John Wighton
Posted: Wed Jan 23, 2013 1:18 pm Post subject: Re: Fusalage fuel stains |
I now own Steve V's first Europa. The only trouble l had was entirely self inflicted. I refuelled to top of filler on a cold day and lost a few litres out the overflow when the fuel warmed up. Unfortunately the fuel attacked the edges of my nice G-IPOD registration on the fuselage so they now curl slightly.
I now try not overfill unless l go flying immediately.
Incidently l am now in Switzerland working for Pilatus Aircraft. Does anyone have the contact details of an Swiss Europa owners?
_________________ John Wighton
Europa XS trigear G-IPOD |
budyerly(at)msn.com Guest
Posted: Fri Jan 25, 2013 5:54 pm Post subject: Fusalage fuel stains |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Regarding fuel staining and burping.
In the UK I would advise not filling to the top as all changes to the vent system should be approved. I have been an advocate of some sort of underside drain out the bottom of the aircraft because of the low pressure area on top of the aircraft sucks the small amount of fuel out the vent over the rear fuselage.
I agree that it would be nice to see a small elbow in the fill tube near the top to allow the expanding fuel (fill in the cold and let the plane sit in the sun or warm garage). The elbow would lead to a vent line on the bottom of the aircraft. Fuel still drains out, but doesn't stain our paint.
See the fuel vent posts from the archives or mine on www.customflightcreations.com. My website was corrupted by a well meaning friend and some data lost but the fuel vent is still on it.
Best Regards,
Bud Yerly
