nail13zg(at)centurytel.ne Guest
Posted: Wed Jan 23, 2013 10:53 am Post subject: Water Temp |
Does anyone use an actual water temperature taken from a sensor on a water hose? Or are you just using the sensor from the block as water temp?
I have not flown my plane yet, but ground runs show a higher, and climbing, in-hose temp than the block temp.
Trey Moran
Kitfox M5
| | - The Matronics Stratus-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Stratus-List |
larrycmcfarland(at)gmail. Guest
Posted: Wed Jan 23, 2013 3:13 pm Post subject: Water Temp |
Hi Trey,
I placed my temp sensor in the hose at the bottom of the firewall and it was good for telling when the thermostat opened.
Things would perk along at ambient for a while, then about 5 minutes in, the temps would rise steadily to the thermostat setting.
Getting a read higher than the block temp is probably because the thermostat is at the outgoing end of the block and the head sensor is at
the other end. I’d rationalize that the water was closer to the hottest area just before the thermostat opened and that was the reading you
got. See link, http://www.macsmachine.com/images/subaruengine/small/hose-connector-with-pressur.gif
Good luck,
Larry McFarland
From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Trey Moran
Sent: Wednesday, January 23, 2013 11:45 AM
To: stratus-list(at)matronics.com
Subject: Water Temp
Trey Moran
Kitfox M5
| Quote: | | http://www.matronics.com/Navigator?Stratus-List | 01234567
